[OpenLayers-Users] Re: ArcGISCache example's URL
Tobias Reinicke ramotswa at gmail.com
Wed Feb 29 03:45:52 EST 2012
Morning,
I've somewhat managed to get it to work... I say somewhat because the
requests are coming in for the correct tiles, I just have to figure
out how to add some custom parameters at the end of every tile request
so that it passes the security it's coming from.
my layer def:
var myLayer = new OpenLayers.Layer.ArcGISCache('MyLayer',
          "URL THAT ENDS JUST BEFORE THE \L01 folder",
               tileOrigin: agsTileOrigin,
               useAGS: false,
               useArcGISServer: false,
               isBaseLayer: false,
               type: 'jpg'
My slight confusion is that in the api docs it says to use "useAGS"
and in the example it says to use: "UseArcGISServer".. so I just used
both and it seemed to work.
(http://dev.openlayers.org/releases/OpenLayers-2.11/doc/apidocs/files/OpenLayers/Layer/ArcGISCache-js.html)
Hope that helps...
Toby
On 28 February 2012 21:33, myOpenLayersUName <joanne.mcgraw at sympatico.ca> wrote:
> Hello,
> Is there anyone out there who has been able to apply the approach suggested
> by the "ArcGIS Server Map Cache Example (Direct Access)"
> (http://openlayers.org/dev/examples/arcgiscache_direct.html) on their own
> ArcGIS Server? That is, has anyone been able to set up their own server to
> enable direct access to the cache?
> If yes, I'd really appreciate learning how you are able to get direct access
> following the URL examples provided in the example.
> Cheers,
> jtm
> View this message in context: http://osgeo-org.1560.n6.nabble.com/ArcGISCache-example-s-URL-tp4488961p4529287.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
