[OpenLayers-Users] Re: overlaying tiled WMS on top of bing
Kjel Anderson kanderson at truevectortech.com
Thu Jan 26 13:44:46 EST 2012
Looking at it now I see the version that is working "best" is with the wms
layer being untiled.
  function init(){
                // if this is just a coverage or a group of them, disable a
few items,
                // and default to jpeg format
                format = 'image/png';
                var bounds = new OpenLayers.Bounds(
                    -19840232, 2028971.375,
                    -7262943, 11534410
                var options = {
                    controls: [],
                    maxResolution: 49130.03515625,
                    projection: "EPSG:900913",
                    units: 'm'
                map = new OpenLayers.Map('map', options);
            var road = new OpenLayers.Layer.Bing({
                key: apiKey,
                type: "Road"
            var hybrid = new OpenLayers.Layer.Bing({
                key: apiKey,
                type: "AerialWithLabels"
            var aerial = new OpenLayers.Layer.Bing({
                key: apiKey,
                type: "Aerial"
            map.addLayers([road, hybrid, aerial]);
            tiled = new OpenLayers.Layer.WMS(
                "dwt_lata_proj - Untiled", "
http://localhost:8080/geoserver/wms",
                    width: '512',
                    srs: 'EPSG:900913',
                    layers: 'DWT:dwt_lata_proj',
                    height: '386',
                    styles: '',
                    format: format,
                    transparent:true,
                    numZoomLevels:19,
                    minResolution:0.5971642833948135,
                    maxResolution:156543.03390625
                {singleTile: true, ratio: 1}
            map.addLayer(untiled);
            // build up all controls
            map.addControl(new OpenLayers.Control.PanZoomBar({
                position: new OpenLayers.Pixel(2, 15)
            map.addControl(new OpenLayers.Control.Navigation());
            map.addControl(new OpenLayers.Control.Scale($('scale')));
            map.addControl(new OpenLayers.Control.MousePosition({element:
$('location')}));
            map.addControl(new OpenLayers.Control.LayerSwitcher());
On Thu, Jan 26, 2012 at 10:33 AM, maw269 <maw269 at gmail.com> wrote:
> Is your bing layer imagery? I've had nothing but issues combining layers
> with
> Bing Imagery layers.
> Anyhow, can you post the relevant code so we could take a look?
> --Matt
> http://osgeo-org.1560.n6.nabble.com/overlaying-tiled-WMS-on-top-of-bing-tp4341145p4341275.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120126/5284a488/attachment.html
