[OpenLayers-Users] Re: overlaying tiled WMS on top of bing
Kjel Anderson kanderson at truevectortech.com
Thu Jan 26 14:11:33 EST 2012
Hmmm. No dice with these changes incorporated. I'm not sure what is going
on. For the curious there is a live link here:
http://truevector.skygone.net:8080/DWTEdstest/
On Thu, Jan 26, 2012 at 10:50 AM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi,
> you put most layer options in the layer params object, and you should
> set the maxExtent on the WMS layer. Something like
>            tiled = new OpenLayers.Layer.WMS(
>                "dwt_lata_proj - Untiled",
> "http://localhost:8080/geoserver/wms",
>                     layers: 'DWT:dwt_lata_proj',
>                     styles: '',
>                    format: format,
>                    transparent:true,
>                    numZoomLevels:19,
>                    maxExtent: new OpenLayers.Bounds(
>                        -19840232, 2028971.375,
>                        -7262943, 11534410
>                    minResolution:0.5971642833948135,
>                    maxResolution:156543.03390625,
>                     singleTile: true,
>                    ratio: 1
> The above should work both with singleTile: true and without.
> Andreas.
> On Thu, Jan 26, 2012 at 7:44 PM, Kjel Anderson
> <kanderson at truevectortech.com> wrote:
> > Looking at it now I see the version that is working "best" is with the
> wms
> > layer being untiled.
> >   function init(){
> >                 // if this is just a coverage or a group of them,
> disable a
> > few items,
> >                 // and default to jpeg format
> >                 format = 'image/png';
> >                 var bounds = new OpenLayers.Bounds(
> >                     -7262943, 11534410
> >                 var options = {
> >                     controls: [],
> >                     maxResolution: 49130.03515625,
> >                     projection: "EPSG:900913",
> >                     units: 'm'
> >                 map = new OpenLayers.Map('map', options);
> >             var road = new OpenLayers.Layer.Bing({
> >                 key: apiKey,
> >                 type: "Road"
> >             var hybrid = new OpenLayers.Layer.Bing({
> >                 key: apiKey,
> >                 type: "AerialWithLabels"
> >             var aerial = new OpenLayers.Layer.Bing({
> >                 key: apiKey,
> >                 type: "Aerial"
> >             map.addLayers([road, hybrid, aerial]);
> >                     width: '512',
> >                     srs: 'EPSG:900913',
> >                     height: '386',
> >                     styles: '',
> >                     format: format,
> >                     transparent:true,
> >                     numZoomLevels:19,
> >                 {singleTile: true, ratio: 1}
> >             map.addLayer(untiled);
> >             // build up all controls
> >             map.addControl(new OpenLayers.Control.PanZoomBar({
> >                 position: new OpenLayers.Pixel(2, 15)
> >             map.addControl(new OpenLayers.Control.Navigation());
> >             map.addControl(new OpenLayers.Control.Scale($('scale')));
> >             map.addControl(new OpenLayers.Control.MousePosition({element:
> > $('location')}));
> >             map.addControl(new OpenLayers.Control.LayerSwitcher());
> > On Thu, Jan 26, 2012 at 10:33 AM, maw269 <maw269 at gmail.com> wrote:
> >> Is your bing layer imagery? I've had nothing but issues combining layers
> >> with
> >> Bing Imagery layers.
> >> Anyhow, can you post the relevant code so we could take a look?
> >> --Matt
> >> View this message in context:
> http://osgeo-org.1560.n6.nabble.com/overlaying-tiled-WMS-on-top-of-bing-tp4341145p4341275.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> > Users mailing list
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120126/5e9ead8b/attachment.html
