[OpenLayers-Users] How to Create buffer around point?
Raymond Nijssen r.nijssen at terglobo.nl
Mon Jan 30 03:57:16 EST 2012
Try JSTS. It integrates very well with OpenLayers and contains the
Buffer-function client side in javascript. That means it works on
features in a vector-layer. I'm not sure if that is what you're looking
for though.
https://github.com/bjornharrtell/jsts
Good luck!
Raymond
On 01/30/2012 09:06 AM, Robert Buckley wrote:
> Hi,
>  I need to implement a "simple" buffer tool. The tool should simply
> place a Buffer zone around the position clicked in the map when the
> tool is activated.
> ...the tool should work like this...
> 1. Activate tool in toolbar
> 2. Set Radius in map units
> 3. Click in map
> 4. buffer polygon based on the set radius is created and rendered in
> the map
> My system is Geoserver 2.1.2 / Postgis 1.5
> I have done this with an sld and also in postgis ...but I really need
> the real-time effect in the map!
> any help or examples would be great,
> yours,
> Robert
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Terglobo
Ampèrestraat 110
5223 CT 's-Hertogenbosch
06-25314983
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120130/e530de14/attachment.html
