[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Gery .
gamejihou at hotmail.com
Wed Jul 4 03:16:06 PDT 2012
Hola Pedro,
I don't know if this helps, but you're using firebug as add-on of firefox or the one it comes with OpenLayers? I think you're using the first one. I've had better results (generally spoken) with the second one, just add the path of the javascript to your html <link>, I don't remember well the path but if I'm not wrong is /openlayers/lib/openlayers/Firebug.js, you can google it also. That js script is really useful, it tells in detail where the error is (ie. which js script and which line), at least in my case. Also, even though I don't work with geoserver or bing, I think you have to specify the projection in bing, but not sure. Sometimes I found that projection stuff is the one that *ucks everything.
Hope this helps,
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
Date: Wed, 4 Jul 2012 11:06:36 +0100
To: ramotswa at gmail.com; openlayers-users at lists.osgeo.org
Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
Also no erros on console...
Anybody have an ideia?
all the code here:
http://pastebin.com/mRnDC3UG
Em 04-07-2012 10:58, Toby Reinicke escreveu:
Umm, yes, theoretically, although I'm slightly confused why
there is only one tab and hasn't got a response one. Your syntax
looks fine, although others might be able to confirm that. As
for proxy, as you say you should be fine, and if it wasn't you'd
get some cross domain errors in your console..
Sorry I can't help more.
Toby
On 4 Jul 2012, at 10:27, Pedro Costa <pedrocostaarma at sapo.pt>
wrote:
Hi Tobias,
This(image attached)?
Em 04-07-2012 10:21, Tobias Reinicke escreveu:
If you expand that "options.wfs" in the
firebug console, what does the "response" tab have in it?
On 4 July 2012 10:09, Pedro
wrote:
I forgot image....
-------- Mensagem Original --------
Assunto:
Data:
Wed, 04 Jul 2012 09:56:54 +0100
De:
Para:
I'm trying to add vector data to my map from geoserver but data don't
show up.
I tried like that:
var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
strategies: [new OpenLayers.Strategy.BBOX()],
protocol: new OpenLayers.Protocol.WFS({
url: "http://localhost:8080/geoserver/testes/wfs",
featurePrefix:"testes",
featureType: "testes:equipamentos",
featureNS: "namespacetestes.pt",
srsName: "EPSG:900913",
geometryName: "the_geom",
version: "1.0.0"
map.addLayer(wfs);
I'm using only data from localhost (my computer) so i don't need proxy
right?
Using firebug I can see that the request is made, but returns nothing
(image attached).
Can anybody help me?
Thanks
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
<request.png>
Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120704/e97f62c3/attachment-0001.html>
