[OpenLayers-Users] Fwd: my vector data don't show up - wfs
Pedro Costa pedrocostaarma at sapo.pt
Thu Jul 5 11:23:40 PDT 2012
I can finally continue studying and playing :-)
Thanks
Em 05-07-2012 19:19, Gery . escreveu:
> Nice to hear that it finally work!, enjoy it =)
> Cheers,
> Gery
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie NICHT, wenn es NICHT notwendig ist.
>> Date: Thu, 5 Jul 2012 19:14:43 +0100
>> From: pedrocostaarma at sapo.pt
>> To: gamejihou at hotmail.com; openlayers-users at lists.osgeo.org
>> Subject: Re: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
>> Gery and others,
>> Thank you for your help. Now i can see WFS on html page (ubuntu)!!!!!!!!
>> I'm just add host 'mydomain:8080' to allowed host in proxy file, change
>> the path to python and put a missing '...
>> Thank you to all
>> Em 05-07-2012 18:05, Gery . escreveu:
>>> Hello Pedro,
>>> uhmm one question, where did you put your html file? I work in rhel and my directories are in /var/www/html/
>>> Cheers,
>>> Gery
>>>> Date: Thu, 5 Jul 2012 16:28:04 +0100
>>>> Thanks for helping me.
>>>> I move my html files to a ubuntu server for testing and now i can't put
>>>> proxy to work...
>>>> Apache give me this error:
>>>> (13)Permission denied: exec of
>>>> '/var/www/pmapper-4.2.0/cgi-bin/proxy.py' failed
>>>> Premature end of script headers: proxy.py
>>>> Does anybody know the cause?
>>>> Thanks
>>>> Em 04-07-2012 18:30, Gery . escreveu:
>>>> It seems that firefox should be the problem, people tried the php code
>>>> and that worked for them. The error in firebug gives you something else
>>>> that may help to trace the source of error?
>>>> si NO es necesario.
>>>> Date: Wed, 4 Jul 2012 18:02:59 +0100
>>>> From: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>
>>>> To: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>;
>>>> openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>
>>>> Thanks for your help Gery.
>>>> I'm already tried with others browsers but the wfs doesn't show up.
>>>> I had found some links that you tell me.
>>>> I am tried a lot of alternatives and I not discovered the problem.
>>>> You think the problem is firefox? If so why not appear in the IE wfs?
>>>> I'm confused
>>>> Em 04-07-2012 17:55, Gery . escreveu:
>>>> This one may help you also, it worked for some people out there:
>>>> http://www.webdeveloper.com/forum/showthread.php?t=187247
>>>> Cheers,
>>>> si NO es necesario.
>>>> From: gamejihou at hotmail.com<mailto:gamejihou at hotmail.com>
>>>> To: pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>;
>>>> Subject: RE: [OpenLayers-Users] Fwd: my vector data don't show up - wfs
>>>> Date: Wed, 4 Jul 2012 16:52:22 +0000
>>>> Hi Pedro,
>>>> I was reading about this error in google and it seems that this is one
>>>> of the solutions, you have to use this: var url = 'proxy_php.php?fn=' +
>>>> encodeURIComponent(src);
>>>> it seems that the problem is ajax (as far I understand), but it can be
>>>> firefox, try first in IE or safari to see what happens. Also this page
>>>> is suggested about the php code above:
>>>> http://developer.yahoo.com/javascript/howto-proxy.html
>>>> This page is in spanish, it may help you:
>>>> http://www.forosdelweb.com/f127/ayuda-access-restricted-uri-denied-599455/
>>>> Cheers,
>>>> Gery
>>>> si NO es necesario.
>>>> Date: Wed, 4 Jul 2012 15:04:39 +0100
>>>> Thank you Gery.
>>>> Now my proxy is working but i got this error in firebug:
>>>> 'Access to restricted URI denied'
>>>> My code:
>>>> http://pastebin.com/AGAFGSfn
>>>> Em 04-07-2012 11:37, Gery . escreveu:
>>>> Hi Pedro,
>>>> Glad to hear that it was useful to you and it worked. Well, I think you
>>>> better do what this console says, it is a very clever one =)
>>>> If it says that it needs a proxy, it is very likely it needs one, just
>>>> add the one you use, localhost:8080 or something like that, you can
>>>> start playing with that and the FB console will tell you what to do
>>>> after each step. Trust in this console, it's our friend =)
>>>> Cheers,
>>>> Gery
>>>> si NO es necesario.
>>>> Date: Wed, 4 Jul 2012 11:33:24 +0100
>>>> Thanks Gery...
>>>> I think that now i'm using ol firebug because i got alerts:
>>>> proxyNeeded Object { url="http://localhost:8080/geoserver/testes/wfs"}
>>>> This means i nedd proxy despite i'm using only local data?
>>>> Thanks
>>>> Em 04-07-2012 11:16, Gery . escreveu:
>>>> Hola Pedro,
>>>> I don't know if this helps, but you're using firebug as add-on of
>>>> firefox or the one it comes with OpenLayers? I think you're using the
>>>> first one. I've had better results (generally spoken) with the second
>>>> one, just add the path of the javascript to your html <link>, I don't
>>>> remember well the path but if I'm not wrong is
>>>> /openlayers/lib/openlayers/Firebug.js, you can google it also. That js
>>>> script is really useful, it tells in detail where the error is (ie.
>>>> which js script and which line), at least in my case. Also, even though
>>>> I don't work with geoserver or bing, I think you have to specify the
>>>> projection in bing, but not sure. Sometimes I found that projection
>>>> stuff is the one that *ucks everything.
>>>> Hope this helps,
>>>> Gery
>>>> si NO es necesario.
>>>> Date: Wed, 4 Jul 2012 11:06:36 +0100
>>>> To: ramotswa at gmail.com<mailto:ramotswa at gmail.com>;
>>>> Also no erros on console...
>>>> Anybody have an ideia?
>>>> all the code here:
>>>> http://pastebin.com/mRnDC3UG
>>>> Em 04-07-2012 10:58, Toby Reinicke escreveu:
>>>> Umm, yes, theoretically, although I'm slightly confused why there is
>>>> only one tab and hasn't got a response one. Your syntax looks fine,
>>>> although others might be able to confirm that. As for proxy, as you say
>>>> you should be fine, and if it wasn't you'd get some cross domain errors
>>>> in your console..
>>>> Sorry I can't help more.
>>>> Toby
>>>> On 4 Jul 2012, at 10:27, Pedro Costa
>>>> <pedrocostaarma at sapo.pt<mailto:pedrocostaarma at sapo.pt>> wrote:
>>>> Hi Tobias,
>>>> This(image attached)?
>>>> Em 04-07-2012 10:21, Tobias Reinicke escreveu:
>>>> If you expand that "options.wfs" in the firebug console, what does the
>>>> "response" tab have in it?
>>>> On 4 July 2012 10:09, Pedro Costa
>>>> I forgot image....
>>>> -------- Mensagem Original --------
>>>> Assunto: my vector data don't show up - wfs
>>>> Data: Wed, 04 Jul 2012 09:56:54 +0100
>>>> De: Pedro Costa <pedrocostaarma at sapo.pt><mailto:pedrocostaarma at sapo.pt>
>>>> Para:
>>>> Hi,
>>>> I'm trying to add vector data to my map from geoserver but data don't
>>>> show up.
>>>> I tried like that:
>>>> var wfs = new OpenLayers.Layer.Vector("Equipamentos_WFS", {
>>>> strategies: [new OpenLayers.Strategy.BBOX()],
>>>> protocol: new OpenLayers.Protocol.WFS({
>>>> url: "http://localhost:8080/geoserver/testes/wfs"<http://localhost:8080/geoserver/testes/wfs>,
>>>> featurePrefix:"testes",
>>>> featureType: "testes:equipamentos",
>>>> featureNS: "namespacetestes.pt<http://namespacetestes.pt>",
>>>> srsName: "EPSG:900913",
>>>> geometryName: "the_geom",
>>>> version: "1.0.0"
>>>> map.addLayer(wfs);
>>>> I'm using only data from localhost (my computer) so i don't need proxy
>>>> right?
>>>> Using firebug I can see that the request is made, but returns nothing
>>>> (image attached).
>>>> Can anybody help me?
>>>> Thanks
>>>> Users mailing list
>>>> Users at lists.osgeo.org<mailto:Users at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>> <request.png>
>>>> _______________________________________________ Users mailing list
