[OpenLayers-Users] Is there an easy way to center and zoom the map automatically based on the placemarks that are on it?
Aaron E-J
azintirea at gmail.com
Fri Jul 6 13:25:30 PDT 2012
What it essentially comes down to is I haven't figured out how to get an
array of coordinates that represent all the filtered placemarks on the map.
If I could get this, it would be fairly easy to set and center the BBox. Does
anyone have any examples of this for KML on a vector layer implemented
using the http protocol? Thanks a lot.
Aaron E-J
http://otherrealm.org
http://aaronej.blogspot.com
Vision without action is a daydream,
Action without vision is a nightmare,
One needs both to succeed.
On Thu, Jul 5, 2012 at 1:45 PM, Someone [via OSGeo.org] <
ml-node+s1560n4986344h30 at n6.nabble.com> wrote:
> Here is a link to the kml file that I am using: http://66.230.78.217/venuesComplete.kml
On 2012-07-05 11:17, Someone whote:
> I'm getting a "bounds is null" error when I try to implement this line of
> code.
Probably something simple I'm not doing but I can't figure out what this
> is. And suggestions appreciated.
function showVenues(state, city, venue){
var kmllayer = new OpenLayers.Layer.Vector(
"KML", {
strategies: [filterStrategy, new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "venuesComplete.kml",
format: new OpenLayers.Format.KML({
placemarksDesc:true,
extractStyles: true,
extractAttributes: true
attribution:'coordinates'
select = new OpenLayers.Control.SelectFeature(kmllayer);
kmllayer.events.on({
"featureselected": onFeatureSelect,
"featureunselected": onFeatureUnselect
map.addControl(select);
select.activate();
function onPopupClose(evt) {
select.unselectAll();
function onFeatureSelect(event) {
var feature = event.feature;
var selectedFeature = feature;
var popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
new OpenLayers.Size(100,100),
"<h2>"+feature.attributes.name + "</h2>" +
feature.attributes.description
+'<br>'+feature.attributes.Point.coordinates,
null,
true,
onPopupClose
document.getElementById('venueName').value=feature.attributes.name;
feature.popup = popup;
map.addPopup(popup);
function onFeatureUnselect(event) {
if(feature.popup) {
map.removePopup(feature.popup);
feature.popup.destroy();
delete feature.popup;
clearFilter();
map.zoomToExtent(kmllayer.getDataExtent());
/* get the following message in firebug:
bounds is null
zoomToExtent(bounds=null, closest=undefined)Map.js (line 2250)
showVenues(state="", city="", venue="Fox Theatre -
Tucson")index.php (line 1204)
init()index.php (line 1259)
(?)()index.php (line 1126)
f(b=Document
index.php#?q=displayGetEventNames&str=||||||||Fox%20Theatre||||||||||||||||date,
f=[function()])jquery.min.js (line 2)
f(b=Document
c=[function()])jquery.min.js (line 2)
f(a=undefined)jquery.min.js (line 2)
f()jquery.min.js (line 2)
error source line:
[Break On This Error]
var center = bounds.getCenterLonLat();
function clearFilter(){
filterStrategy.setFilter(null);
function setFilter(){
/****returned from a php file via a .post request****
$venueFilters = <<<'EOD'
<script>
filter=new OpenLayers.Filter.Logical({
type: OpenLayers.Filter.Logical.OR,
filters: [
EOD;
$firstVenue = true;
foreach ($venueName as $k => $v) {
if ($firstVenue) {
$venueFilters.= <<<EOD
new OpenLayers.Filter.Comparison({
type: OpenLayers.Filter.Comparison.LIKE,
property: 'name',
value: "$v"
EOD;
} else {
property: 'name',
value: "$v"
EOD;
$firstVenue = false;
$venueFilters.= <<<'EOD'
setFilter();
</script>
EOD;
filterStrategy.setFilter(filter);
function init() {
map = new OpenLayers.Map('map');
var google_map_layer = new OpenLayers.Layer.Google(
'Google Map Layer',
type: google.maps.MapTypeId.HYBRID
map.addLayer(google_map_layer);
state="";
state+=document.getElementById('stateProvDesc').value;
city="";
city+=document.getElementById('cityZip').value;
venue="";
venue+=document.getElementById('venueName').value;
showVenues(state,city,venue);
map.addControl(new OpenLayers.Control.LayerSwitcher({}));
map.zoomToMaxExtent();
On 7/4/2012 3:17 AM, Tobias Reinicke wrote:
The same function is also available for vector layers;
http://dev.openlayers.org/docs/files/OpenLayers/Layer/Vector-js.html#OpenLayers.Layer.Vector.getDataExtent
I presume you will have set your kml layer up somewhere along the lines
of;
var myKMLLayer = new OpenLayers.Layer.Vector("KML", {
strategies: [new OpenLayers.Strategy.Fixed()],
url: "whatever",
extractAttributes: true,
maxDepth: 2
Then all you do is call
map.zoomToExtent(myKMLLayer.getDataExtent());
That work for you?
Toby
On 4 July 2012 01:21, Aaron E-J <[hidden
email]<http://osgeo-org.1560.n6.nabble.com/user/SendEmail.jtp?type=node&node=4985988&i=0>
> wrote:
> Do you have, or know where I could find, an example of this being
> implemented on KML layer?
> Aaron E-Jhttp://www.otherrealm.orghttp://www.prospectdesigns.com
> On 7/3/2012 5:52 PM, Greg Allensworth wrote:
> the placemarks that are on it?I have it so that one can filter
> placemarks based on user input but I'm not sure how to dynamically
> update the map to fit the newly filtered content.Thanks for any insight
> that can be given regarding this matter.
> An OpenLayers.Layer.Markers instance, has a method called getDataExtent()
> This should do most of what you want.
> It's not automatic, though. You'd still need to call map.zoomToExtent()
> after the markers have been added to the layer.
> http://dev.openlayers.org/docs/files/OpenLayers/Layer/Markers-js.html
> Users mailing list
> [hidden email]<http://osgeo-org.1560.n6.nabble.com/user/SendEmail.jtp?type=node&node=4985988&i=1>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Users mailing list
[hidden email]<http://osgeo-org.1560.n6.nabble.com/user/SendEmail.jtp?type=node&node=4985988&i=2>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120706/c4a61be9/attachment.html>
