[OpenLayers-Users] Component returned failure code: 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]
Aaron E-J
azintirea at gmail.com
Wed Jul 11 11:52:01 PDT 2012
Well, now it's happening using: http://openlayers.org/dev/OpenLayers.js as
well. Will try an earlier version and see if that fixes it
Aaron E-J
http://otherrealm.org
http://aaronej.blogspot.com
Vision without action is a daydream,
Action without vision is a nightmare,
One needs both to succeed.
On Wed, Jul 11, 2012 at 12:28 PM, Aaron E-J <azintirea at gmail.com> wrote:
> This only seems to be for the local copy I have (lib/OpenLayers.js), using
> http://openlayers.org/dev/OpenLayers.js works find
> Aaron E-J
> On Wed, Jul 11, 2012 at 12:19 PM, Aaron E-J <azintirea at gmail.com> wrote:
>> I started getting a strange message on occasion (usually happens but
>> occasionally does not) that I'm not really sure how to fix it. There are
>> two forms of the same message in firebug, both seem to be about the same
>> thing:
>> Uncaught exception: [Exception... "Component returned failure code:
>> 0x8000ffff (NS_ERROR_UNEXPECTED) [nsIDOMHTMLDocument.implementation]"
>> nsresult: "0x8000ffff (NS_ERROR_UNEXPECTED)" location: "JS frame ::
>> http://localhost/phpEx/lib/OpenLayers/Renderer/SVG.js :: <TOP_LEVEL> ::
>> line 77" data: no]
>> error source line:
>> return (document.implementation &&
>> The function that this appears to be effecting:
>> * APIMethod: supported
>> * Returns:
>> * {Boolean} Whether or not the browser supports the SVG renderer
>> supported: function() {
>> var svgFeature = "http://www.w3.org/TR/SVG11/feature#";
>> (document.implementation.hasFeature("org.w3c.svg", "1.0") ||
>> document.implementation.hasFeature(svgFeature + "SVG", "1.1")
>> "BasicStructure", "1.1") ));
>> I'm using the latest Firefox release (13.0.1) and it should handle SVG no
>> problem… My guess is this is a bug related to OpenLayers v2.12. Does
>> anyone know whether this is, in fact, a bug and whether it is being dealt
>> with? Thanks.
>> Aaron E-J
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120711/376a4ac9/attachment-0001.html>
