[OpenLayers-Users] problem with display place from a local kml file
GANG WU
ycwg0103 at gmail.com
Thu Jul 12 06:27:50 PDT 2012
Hi everyone,
Here is my question. I am using a simple php file to upload local kml file.
After the file has been uploaded, the content will be read into array of
features with OpenLayers.Format.KML object. But the problems is that all
the features map to the wrong position. Is it something wrong with
projection?
here is my code:
map = new OpenLayers.Map('map_element');
var google_map = new OpenLayers.Layer.Google('Google Layer', {});
map.addLayer(google_map);
if (!map.getCenter()) {
map.zoomTo(1);
var features = [];
var kml = new OpenLayers.Format.KML({
extractAttributes : true,
extractStyles : true
features= kml.read(responseData);
//alert(features);
var strategy =new OpenLayers.Strategy.Cluster();
var vector_layer = new OpenLayers.Layer.Vector('PlaceMarker', {
projection : new OpenLayers.Projection('EPSG:4326'),
strategies : [strategy]
var vector_style = new OpenLayers.Style({
'fillColor' : '#669933',
'fillOpacity' : .8,
'fontColor' : '#f0f0f0',
'fontFamily' : 'arial, sans-serif',
'fontSize' : '.9em',
'fontWeight' : 'bold',
'label' : '${num_points}',
'pointRadius' : '${point_radius}',
'strokeColor' : '#aaee77',
'strokeWidth' : 3
// Second parameter contains a context parameter
context : {
num_points : function(feature) {
return (feature.cluster) ? feature.attributes.count : 5;
point_radius : function(feature) {
var pix = 8;
if(feature.cluster) {
pix = feature.attributes.count + 7;
return pix;
var vector_style_select = new OpenLayers.Style({
'fillColor' : '#cdcdcd',
'fillOpacity' : .9,
'fontColor' : '#232323',
'strokeColor' : '#ffffff'
// Create a style map object and set the 'default' intent to the
var vector_style_map = new OpenLayers.StyleMap({
'default' : vector_style,
'select' : vector_style_select
// Add the style map to the vector layer
vector_layer.styleMap = vector_style_map;
// Add a select feature control
var select_feature_control = new OpenLayers.Control.SelectFeature(
vector_layer, {})
map.addControl(select_feature_control);
select_feature_control.activate();
vector_layer.events.register('featureselected', this, on_select_feature);
vector_layer.events
.register('featureunselected', this, on_unselect_feature);
map.addLayer(vector_layer);
vector_layer.addFeatures(features);
Here is the result
<http://www.nabble.com/>
*Gang Wu*
MS Information Science
University of Pittsburgh
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120712/6ccda83b/attachment-0001.html>
