[OpenLayers-Users] wmsgetfeatureinfo with url on alternative port not firing on client side
Andreas Hocevar ahocevar at opengeo.org
Fri Jul 13 23:49:46 PDT 2012
Then something must be wrong with your http proxy. Try to issue a
GetFeature request from the browser's addess bar and see what you get. Or
look in the net pane of your browser's developer tools.
Andreas.
On Jul 14, 2012 12:30 AM, "Giuseppe De Marco" <peppelinux at yahoo.it> wrote:
> Thank you Andreas,
> I'm tryng to tell you that
> django server runs on port 8000
> web-proxy is a django app that runs on port 8000 and proxy me to the wms
> on port 80
> if I use port 8000 (django and, obviously, proxy-app) wmsgetfeatureinfo
> doesn't fire.
> If I reconfigure all the services on port 80 everything works fine.
> Listen, if I get the webpage from the httpd on port 8000 then I try to
> connect with wmsgetfeatureinfo on a wms on port 80 the ajax console tells
> me: "Same origin blah blah", so I know it because I've debugged it yet.
> If I configure every servers on port 80 every works great
> If I configure httpd on port 8000 and wmsgetfeatureinfo url on port 8000
> (web-proxy) happens that the client doesn't do the connection, so the Same
> origin restriction doesn't appear because event not firing at all.
> I understand what you want to tell me, I know it, but my problem is
> another and really strange...
> *Da:* Andreas Hocevar <ahocevar at opengeo.org>
> *A:* Giuseppe De Marco <peppelinux at yahoo.it>
> *Cc:* "openlayers-users at lists.osgeo.org" <openlayers-users at lists.osgeo.org>
> *Inviato:* Venerdì 13 Luglio 2012 23:36
> *Oggetto:* Re: [OpenLayers-Users] wmsgetfeatureinfo with url on
> Again: the reason for what you're seeing is the browser's Same Origin
> Policy: http://lmgtfy.com/?q=same+origin+policy&l=1
> Andreas.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120714/8a16a02e/attachment.html>
