[OpenLayers-Users] Accessing an Offline Tile Store
    Joaquim Muchaxo
    joaquim at rocketmail.com
    Mon Jul 23 07:51:21 PDT 2012
  the tiles on disk have a known layout into folders and files, so a mapping from a tile url to files is possible.
This means you would not need an http request you would open a disk file.
The correspondence from bounding box to tile folder/filename is generally given by a formula. This formula depends on the tile software you have used.
I may help a little more for instance if you are using tilecache or geowebcache.
If other just look it up a little on google.
I'd also suggest you ask this on
http://gis.stackexchange.com/
regards,
Joaquim.
----- Original Message -----
To: openlayers-users at lists.osgeo.org
Cc:
Sent: Friday, 20 July 2012, 6:06
Subject: [OpenLayers-Users] Accessing an Offline Tile Store
Hello All,
I've been looking at the possibility of providing an offline map in a Qt
application.  The QtWebKit component would be used to host an OpenLayers
page inside the application.  As a first cut I have implemented a basic
local web server to provide XYZ tile service to an OL layer from local
mbtiles databases.  This all works, and is more disk-space and
distribution friendly than using raw tiles on the disk.  It has the
disadvantage that the desktop app requires a port (multiple ports on
terminal server machines) and exposes the tile service to external
access (localhost anyway)
I had thought of alternate approach that could eliminate the web
server.  QtWebKit offers a C++ to Javascript bridge that allows js to
make calls to C++ functions and vice versa.  If the transport for tile
requests could be replaced with js calls into the C++ the tile service
code could be subsumed into the C++ widget code and no longer be exposed
to the outside world.   Inspection of the inheritance hierarch of the
XYZ layer would seem to indicate an intimate relationship to HTTP... but
I am a bit of a js neophyte.
I wonder if the replacement of the OL transport layer for base layer
tiles retrieval is even possible?  Has something like this been done?
Regards,
Chris
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
