[OpenLayers-Users] Point symbolizer: triangle + orientation line
Gabriel Vatin
gabriel.vatin at mines-paristech.fr
Fri Jul 27 08:08:30 PDT 2012
Hi Alexandre,
Thanks for your advice. I think I saw this kind of solution here :
http://gaganb.wordpress.com/2010/09/30/draw-line-direction-on-openlayers-feature/
But he's using it for line features.
I'll try to find if there is a way to use it to modify point feature (I
don't need any arrow symbol, but just a line at the top of a triangle,
both of them would have a rotation then).
Gabriel
Le 27/07/2012 16:38, Alexandre Dubé a écrit :
> Hi Gabriel,
> You could try to define your own arrow symbol. There's one defined
> [here], see line 1 :
> OpenLayers.Renderer.symbol.arrow = [0,2, 1,0, 2,2, 1,0, 0,2]
> I haven't tried it, but it could do the trick.
> HTH,
> Alexandre
> [here]
> http://code.google.com/p/rep-olnet/source/browse/trunk/Direction.js?r=61
> On 12-07-27 10:18 AM, Gabriel Vatin wrote:
>> Hello,
>> I'd like to represent mobile objects (WFS layer of points) with a
>> triangle, and a line to show the direction and speed of it. Right
>> now, I can use the default "triangle" symbolizer :
>> symbolizer: {
>> rotation: '${heading}',
>> pointRadius: 6.5,
>> graphicName: 'triangle',
>> strokeColor: 'white',
>> fillColor: color,
>> strokeOpacity: 0.3,
>> strokeWidth: 2,
>> fillOpacity: 0.7
>> Then I use the rotation attribute to turn the trangle. The triangle
>> object is a isosceles triangle, but it is so small that we can't
>> really see its orientation. So is there a method to draw a triangle
>> and a line at the top of it to show the direction ?
>> I just tried to add a new WFS layer with the same origin, but an
>> other symbolizer :
>> defaultStyleD = new OpenLayers.Style({
>> pointRadius: 25,
>> externalGraphic: './img/line.png',
>> graphicYOffset: -50
>> The line.png is an image I made myself. If I display the 2 layers at
>> the same time, that's the kind of result that I want to see... but
>> this is only a trick, and not a real good way to answer my problem !
>> Do you have any idea ?
>> Thanks,
>> Gabriel
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
