[OpenLayers-Users] Point symbolizer: triangle + orientation line
Gabriel Vatin gabriel.vatin at mines-paristech.fr
Fri Jul 27 08:12:32 PDT 2012
I had the same idea, but the thing is I'd like to use vector features :
I have OL Rules to change the color according to some attributes.
Actually, I'd like to have this kind of result :
http://blog.fleetmon.com/wp-content/uploads/2012/07/FleetMon-Explorer-live-real-time-vessel-tracking-and-monitoring-Fleetmon.com-125-2-1024x581.jpg
But with the line at the top of the triangle (direction and speed, and
not passed trajectory).
Le 27/07/2012 17:08, Mr. Puneet Kishor a écrit :
> On Jul 27, 2012, at 10:18 AM, Gabriel Vatin <gabriel.vatin at mines-paristech.fr> wrote:
>> Hello,
>> I'd like to represent mobile objects (WFS layer of points) with a triangle, and a line to show the direction and speed of it. Right now, I can use the default "triangle" symbolizer :
>> symbolizer: {
>> rotation: '${heading}',
>>     pointRadius: 6.5,
>>     graphicName: 'triangle',
>>     strokeColor: 'white',
>>     fillColor: color,
>>     strokeOpacity: 0.3,
>>     strokeWidth: 2,
>>     fillOpacity: 0.7
>> Then I use the rotation attribute to turn the trangle. The triangle object is a isosceles triangle, but it is so small that we can't really see its orientation. So is there a method to draw a triangle and a line at the top of it to show the direction ?
>> I just tried to add a new WFS layer with the same origin, but an other symbolizer :
>> defaultStyleD = new OpenLayers.Style({
>>     pointRadius: 25,
>>     externalGraphic: './img/line.png',
>>     graphicYOffset: -50
>> The line.png is an image I made myself. If I display the 2 layers at the same time, that's the kind of result that I want to see... but this is only a trick, and not a real good way to answer my problem !
>> Do you have any idea ?
> The above is too complicated. Instead, make one image of an arrow (line with triangle showing direction), and then rotate and scale it as needed. See example image at http://dl.dropbox.com/u/3526821/gps.png
> Puneet Kishor
