[OpenLayers-Users] MapIgniter Project
mafonso mafonso333 at gmail.com
Tue Jul 31 05:24:43 PDT 2012
As I said, it is different in technology... and Mapserver + PHP should not
be understimated :)
Of course those platforms are much more mature which leaves out features
comparison.
Cheers,
Marco
2012/7/31 Christian Ledermann [via OSGeo.org] <
ml-node+s1560n4992111h54 at n6.nabble.com>
> On Tue, Jul 31, 2012 at 2:40 PM, mafonso <[hidden email]<http://user/SendEmail.jtp?type=node&node=4992111&i=0>>
> wrote:
> > Thank you Christian for the enlightenment. I will check those projects
> and
> > extract a detailed comparison.
> > At a first sight, Plone is based on Python.
> and on the zope framework.
> > GeoNode is based on Java.
> actually it is a mix of django (python), postgis,  geoserver.  geonetwork
> (java)
> > CartoDB is limited on Free Plan.
> Cartodb is mainly build on Ruby, Nodejs, Postgis
> It is not obvious from their man page but it is open source
> https://github.com/Vizzuality/cartodb
> > MapIgniter is based on PHP, Open Source,
> all of the above are open soure too.
> Best Regards,
> Christian Ledermann
> Nairobi - Kenya
> Mobile : +254 702978914
> If you save the living environment, the biodiversity that we have left,
> you will also automatically save the physical environment, too. But If
> you only save the physical environment, you will ultimately lose both.
> 1) Don’t drive species to extinction
> 2) Don’t destroy a habitat that species rely on.
> 3) Don’t change the climate in ways that will result in the above.
> Users mailing list
> [hidden email] <http://user/SendEmail.jtp?type=node&node=4992111&i=1>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4992111.html
>  To unsubscribe from MapIgniter Project, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4991898&code=bWFmb25zbzMzM0BnbWFpbC5jb218NDk5MTg5OHwtMzgyNzU4ODQz>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapIgniter-Project-tp4991898p4992119.html
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120731/1ad987d1/attachment.html>
