[OpenLayers-Users] Changing styleMap of a OpenLayers.Layer.Vector after map initialization?
alexe100 imoveisnacionais at gmail.com
Sat Jun 2 16:45:33 PDT 2012
Hi
I have a map where user can draw polygons to represent geofences. I want
that geofences where vehicles must be inside to be drawn in green and
geofences where vehicles can not be inside to be drawn in red.
I have the styleMapVermelho (red color) and styleMapVerde (green)
OpenLayers.StyleMap variables.
So, the application starts with the green color selected. I have a button to
change the color to red and vice-versa.
The question is, how to remove the current  OpenLayers.StyleMap and set the
other OpenLayers.StyleMap  when the button is pressed?
Please, see code below for init function:
var map, drawControls;
		var polygonLayer;
		var styleMapVerde;
		var styleMapVermelho;
		function init()
			map = new OpenLayers.Map('mapdiv');
			var wmsLayer= new OpenLayers.Layer.OSM(); //This uses meters in X/Y!!!
			map.addLayer(wmsLayer);
			map.addControl(new OpenLayers.Control.MousePosition());
			//cores para polygon layer
			styleMapVermelho = new OpenLayers.StyleMap(OpenLayers.Util.applyDefaults
				{fillColor: "red", fillOpacity: 0.25, strokeColor: "black"},
				OpenLayers.Feature.Vector.style["default"])
			styleMapVerde = new OpenLayers.StyleMap(OpenLayers.Util.applyDefaults
				{fillColor: "green", fillOpacity: 0.25, strokeColor: "black"},
			polygonLayer = new OpenLayers.Layer.Vector("Polygon Layer",{styleMap:
styleMapVerde});
			map.addLayer(polygonLayer);
			document.getElementById('dentro').checked=true;
			drawControls =
				polygon: new
OpenLayers.Control.DrawFeature(polygonLayer,OpenLayers.Handler.Polygon)
			map.addControl(drawControls['polygon']);
			drawControls['polygon'].activate();
			map.setCenter(new OpenLayers.LonLat(0, 0), 3);
View this message in context: http://osgeo-org.1560.n6.nabble.com/Changing-styleMap-of-a-OpenLayers-Layer-Vector-after-map-initialization-tp4978765.html
