[OpenLayers-Users] openlayers 2.12rc5 & KeyboardDefaults
Eric Lemoine eric.lemoine at camptocamp.com
Tue Jun 5 02:48:16 PDT 2012
On Tue, Jun 5, 2012 at 11:43 AM, Marcelo Bianchi
<mbianchi at gfz-potsdam.de> wrote:
> Hi Eric,
> Thanks for the quick reply and check !
> Yes was exactly this issue. Okay, using the observeElement attribute the
> issue goes away and the results is much improved when compared to the 2.11.
> Maybe to avoid this issue the KeyboardDefaults control should by default be
> attached to the map div if nothing is specified on the class instantiation.
This would break backward compatibility. That's why the default value
wasn't changed.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
