[OpenLayers-Users] Testing ol 2.12 rc6
Andreas Hocevar ahocevar at opengeo.org
Wed Jun 6 07:32:57 PDT 2012
Code would be great. Especially showing your map and layer options.
Thanks,
Andreas.
On Wed, Jun 6, 2012 at 4:14 PM, Ricardo Bayley <ricardo.bayley at gmail.com> wrote:
> Do you mean screenshot or live example or just code ?
> All I am doing is pointing to a different Openlayer js. So, yes with ol 2.11
> worked fine.
> 2012/6/6 Andreas Hocevar <ahocevar at opengeo.org>
>> Hi,
>> Can you share a minimal example that shows the issue? Also, did this
>> work with OpenLayers 2.11?
>> Andreas.
>> On Wed, Jun 6, 2012 at 3:17 PM, Ricardo Bayley <ricardo.bayley at gmail.com>
>> wrote:
>> > Hi folks,
>> > I am testing ol 2.12 rc6 on my web app.
>> > I have a GWC wms layer, google hybrid + google sat.
>> > At start, GWC layer is not loading in the correct zoom layer. When
>> > zooming I
>> > get the blank image.
>> > When checking with GWC I get this message.
>> > 400: X,Y values for the tile index were calculated to be
>> > {81.13292818954577,
>> > 104.17067323102172} which had to be rounded to {81, 104} and exceeds the
>> > threshold of 10%. Perhaps the client is using the wrong origin ?
>> > My map is in south america, so both x and y should be negative, shouldnt
>> > they ?
>> > I think this maybe cause by the Projection & SphericalMercator changes.
>> > Is this so ?
>> > Thanks
>> > Ricardo
>> > _______________________________________________
>> > Users mailing list
>> > Users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
Andreas Hocevar
