[OpenLayers-Users] GetFeature.Control and Oracle View
Steve Way Steve.Way at infotech-enterprises.com
Mon Jun 18 19:35:58 PDT 2012
Hi Everyone,
It seems that when working with an Oracle database view, even if there is an FID column defined which has an underlying Id which points to a Primary Key, the toggle does not work with the select tool.  Features will keep getting added as openlayers generates an auto FID instead of using the FID column.
Is there a way around this?  I am working with a fairly complex data model, and views are the only way of achieving the end result correctly.
Many Thanks,
Steve
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin at infotech-enterprises.com and delete the original message.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120619/1b77fe43/attachment.html>
