[OpenLayers-Users] GetFeature.Control and Oracle View
Andreas Hocevar ahocevar at opengeo.org
Sun Jun 24 02:00:58 PDT 2012
is this with GeoServer? I think it is possible to configure view layers to
get a real fid. You may want to ask this question on the geoserver-users
list.
OpenLayers relies on the fid for wfs transactions.
Andreas.
On Jun 19, 2012 4:48 AM, "Steve Way" <Steve.Way at infotech-enterprises.com>
wrote:
>  Hi Everyone,
> It seems that when working with an Oracle database view, even if there is
> an FID column defined which has an underlying Id which points to a Primary
> Key, the toggle does not work with the select tool.  Features will keep
> getting added as openlayers generates an auto FID instead of using the FID
> column.
> Is there a way around this?  I am working with a fairly complex data
> model, and views are the only way of achieving the end result correctly.
> Many Thanks,
> Steve
> DISCLAIMER:
> This email may contain confidential information and is intended only for
> the use of the specific individual(s) to which it is addressed. If you are
> not the intended recipient of this email, you are hereby notified that any
> unauthorized use, dissemination or copying of this email or the information
> contained in it or attached to it is strictly prohibited. If you received
> this message in error, please immediately notify the sender at Infotech or
> Mail.Admin at infotech-enterprises.com and delete the original message.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120624/00b33002/attachment.html>
