[OpenLayers-Users] OpenLayers in Android
Philipp Austermann phil at patient-radio.de
Tue Jun 26 21:39:57 PDT 2012
Hi Jackie,
quick update: Though bit later than promised, phonegap-compatible
wrapper and usage instructions are online now (as i noticed you're
watching the repository you may have already seen it)
By any means please, please add your phone here if the polyfill works
for you:
https://github.com/Philzen/WebView-MultiTouch-Polyfill/wiki/Device-Chart
(or file a bug if it doesn't)
It's still very new, i only own one android device myself and therefore
need any test feedback i can get.
Cheers!
Phil
Am 25.06.2012 10:48, schrieb Philipp Austermann:
> Yes it can, just tonight i have successfully made a version that
> extends from CordovaWebViewClient instead of WebViewClient, and that
> apparently seamlessly integrates with Phonegap.
> Pls have a go at the current application with your device and help
> filling the device test chart (or issues list if you encounter one) -
> i'll try to push a version for phonegap (incl. inclusion instruction)
> tonight.
> Cheers - Phil
> Am 25.06.2012 10:20, schrieb Jackie Ng:
>> Interesting! Can this be used in conjunction with PhoneGap (namely our
>> derived subclass of DroidGap, which is the entry point activity for a
>> PhoneGap android application) ?
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1560.n6.nabble.com/OpenLayers-in-Android-tp3917561p4983513.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
