[OpenLayers-Users] control event processing conflicts?
Meskanen, Vesa vesa.meskanen at logica.com
Wed Jun 27 03:04:48 PDT 2012
I use the following setup of controls, registered in this order:
   - dragFeature to move vectors around
   - selectFeature to activate vectors
   - the usual mouse Navigation control
   - custom Click hander for creating vectors with a single click
Everything works fine, but as soon as I pan the map with a mouse drag, selectFeature stops working. It's onSelect callback still gets called, but the clicked vector does not get selected (no highlighting, selectedFeatures array remains empty).
Any ideas what is causing this?
Kind regards,
Vesa
Think green - keep it on the screen.
This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120627/175e1a5c/attachment.html>
