[OpenLayers-Users] Zoomify and fractional zoom
David Régade dregade at viewsurf.com
Wed Jun 27 01:51:59 PDT 2012
It can't be so easy. I fixed line 225 with:
              var z = Math.round(this.map.getZoom());
And another bug appeared line 201, same fix:
However on this example, http://david.regade.free.fr/openlayers/, setting zoom
to 3.4 doesn't generate javascript errors anymore but the result isn't correct.
A tile is tried to be drawn and it shouldn't.
I tried to trace where and why this tile is drawn but I'm to new to openlayers
to find where the problem comes from.
Regards
David
On 27/06/2012 08:05, Andreas Hocevar wrote:
> I just see that there is a bug in Zoomify.js, line 225:
>              var z = this.map.getZoom();
> We need the integer of getZoom() here instead.
> Maybe you want to send a pull request with a fix?
> Andreas.
> On Tue, Jun 26, 2012 at 11:33 PM, David Régade<dregade at viewsurf.com>  wrote:
>> I get the last OpenLayers master and this feature doesn't work with the
>> following example:
>> Is there something I'm doing wrong ?
>> When setting up a fractional zoom (by clicking on the button for example)
>> Firebug catches an error.
>> Layer is resized but the tiles are not set correctly.
>> David
>> On 26/06/2012 16:32, Andreas Hocevar wrote:
>>> This is supported in OpenLayers master and the upcoming 2.12 release.
>>> Andreas.
>>> On Tue, Jun 26, 2012 at 3:12 PM, David Régade<dregade at viewsurf.com>
>>>   wrote:
>>>> Hi,
>>>> We use openlayers to display large panoramas. We use ZoomifyImage to
>>>> split
>>>> original image in tiles and Zoomify layer to display these tiles.
>>>> I would like to use fractionalZoom with Zoomify layer but this layer
>>>> doesn't
>>>> support this feature. The main goal is to able to resize displayed tiles
>>>> for
>>>> zoom level 3 from 2.5 to 3.4.
>>>> Does anyone knows how to do that ?
>>>> Thanks in advance
>>>> David REGADE
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
