[OpenLayers-Users] Own map layer in different projection
Olivier Terral olivier at geomatic.ch
Wed Jun 27 07:23:23 PDT 2012
Hi dalori,
For your cache I don't know what is the problem but for your marker I think you just inverted the lon/lat value.
Le 27 juin 2012 à 11:18, dalori a écrit :
> Yes I have. :-)
> <!DOCTYPE HTML>
> <html>
>   <head>
>     <title>Rectangular tiles</title>
>     <style type="text/css">
>       html, body, #map {
>         width: 100%;
>         height: 100%;
>         margin: 0;
>     </style>
>     <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
>     <script>
>       function get_my_url(bounds) {
>         var res = this.map.getResolution();
>         var x = Math.round((bounds.left - this.maxExtent.left) / (res *
> this.tileSize.w));
>         var y = Math.round((this.maxExtent.top - bounds.top) / (res *
> this.tileSize.h));
>         var z = this.map.getZoom();
>         // tiles are named like 0001 instead of simply 1
>         x = "000" + x;
>         x = x.substring(4, 0);
>         y = "000" + y;
>         y = y.substring(4, 0);
>         var path = z + "/" + x + "/tile_" + y + "." + this.type;
>         var url = this.url;
>         if( url instanceof Array) {
>           url = this.selectUrl(path, url);
>         return url + path;
>       var map, point, markers;
>       function init() {
>         point = new OpenLayers.LonLat(54.167258, -131.662903);
>         map = new OpenLayers.Map("map", {
>           tileSize : new OpenLayers.Size(512, 512)
>         map.addLayer(new OpenLayers.Layer.TMS("Name",
> "http://www.bananenhand.de/background/level", {
>           'type' : 'jpg',
>           'getURL' : get_my_url
>         map.setCenter(point, 2);
>         markers = new OpenLayers.Layer.Markers("Markers");
>         map.addLayer(markers);
>         markers.addMarker(new OpenLayers.Marker(point));
>     </script>
>   </head>
>   <body onload="init();">
>     <div id="map"></div>
>   </body>
> </html>
> View this message in context: Re: Own map layer in different projection
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Olivier Terral
GEOMATIC Ingénierie SA
Société du groupe Ringier
Chemin des Croisettes 26
1066 Epalinges
www.geomatic.ch
www.thevirtualcity.ch
Tél:: +41 (21) 651 30 00
Fax: +41 (21) 651 30 09
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120627/4fe6c18f/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120627/4fe6c18f/attachment-0001.gif>
