[OpenLayers-Users] Missing tiles in OSM map
Alessandro Candini
candini at meeo.it
Wed Mar 14 11:23:01 EDT 2012
Thank you Andreas, I solved with the following:
.olImageLoadError{display: none !important;}
And what about performance concerns? I see that in Firefox and in IE map
browsing is definitely slower than in Chrome.
Is a normal difference between browser or it is related to 404 errors?
> Hi,
> this no longer works with recent versions (master and upcoming 2.12).
> Instead, just add the following to your application's css:
> .olImageLoadError {
> background-color: transparent !important;
> If you want an image showing something like "No imagery for this
> region at the current zoom level", you can also set a
> background-image.
> Andreas.
> On Wed, Mar 14, 2012 at 3:14 PM, Alessandro Candini<candini at meeo.it> wrote:
>> Ok, I solved this issue with the following lines:
>> OpenLayers.Util.onImageLoadError = function() {
>> this.src = "http://localhost/static/img/missingTile.png";
>> Where missingTile.png is a completely transparent image of size 256x256.
>> The visualization is now perfect on every browser, but using firebug on
>> Firefox I see that every missing tile produces a 404 error anyway.
>> Can this lead to performance issues and is it possible to avoid these calls?
>>> Hi list.
>>> I produce tiles using mapnik (www.mapnik.org) and I use the following map
>>> definition:
>>> var map = new OpenLayers.Map({
>>> div: "map",
>>> allOverlays: true,
>>> maxExtent: bounds,
>>> projection: fromProj,
>>> displayProjection: toProj,
>>> allowSelection: true,
>>> controls: [new OpenLayers.Control.PanZoomBar(), new
>>> OpenLayers.Control.Navigation()],
>>> var layer = new OpenLayers.Layer.OSM(
>>> layer_dir,
>>> "tiles/${z}/${x}/${y}.png",
>>> {zoomLevels: maxZoom, zoomOffset: minZoom, resolutions: res}
>>> map.addLayer(layer);
>>> The problem is that I have a visualization issue in IE and Chrome: the
>>> missing tiles are represented as pink squares.
>>> Instead in Firefox the visualization is perfect because it simply uses a
>>> white background when the tile is missing.
>>> Is there a map or layer parameter to visualize as white the missing tiles?
>>> Thanks in advance,
>>> Alessandro
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Alessandro Candini
>> MEEO S.r.l.
>> Via Saragat 9
>> I-44122 Ferrara, Italy
>> Tel: +39 0532 1861501
>> Fax: +39 0532 1861637
>> http://www.meeo.it
>> "ATTENZIONE:le informazioni contenute in questo messaggio sono
>> da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
>> al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
>> per errore è tenuto ad informare il mittente ed a rimuoverlo
>> definitivamente da ogni supporto elettronico o cartaceo."
>> "WARNING:This message contains confidential and/or proprietary
>> information which may be subject to privilege or immunity and which
>> is intended for use of its addressee only. Should you receive this
>> message in error, you are kindly requested to inform the sender and
>> to definitively remove it from any paper or electronic format."
>> Users mailing list
Alessandro Candini
MEEO S.r.l.
Via Saragat 9
http://www.meeo.it
