[OpenLayers-Users] Openlayer
Stephen Woodbridge woodbri at swoodbridge.com
Sat Nov 24 17:11:36 PST 2012
I can add a little to Tue's comments.
1. you can look at installing tinyOWS which is part of mapserver.org
releases, this implements WFS-T
2. alternative this is as Tue has suggested do a getfeatureinfo (WMS
request) on the feature, and extract the PK. You can then trivially
write an ajax request in say php, to that you send the PK to to and it
connects to the postgresql/postgis database and deletes the feature.
Both of these assume that the data layer you want to edit is being
served from a postgresql/postgis database. You can NOT safely delete
features from shapefiles.
-Steve W
On 11/24/2012 5:35 PM, Tue Topholm wrote:
> You can't do that with openlayers, except with WFS-T
> You will need to develop it. (simple solution here)
> 1. use getfeatureinfo (WMS request) on the feature, and extract the PK.
> 2. Delete the feature in the database with the PK you got above. (This
> needs to be developed in some server side language)
> 3. Refresh the wms, and it would be removed.
> Med venlig hilsen / Kind regards
> Tue Topholm
> Sugee
> Tlf: +45 32 13 32 32
> W: http://www.sugee.dk
> 2012/11/24 yassine bouderaa <bouderaa.yassine at gmail.com
> <mailto:bouderaa.yassine at gmail.com>>
>     Hi.
>     I need to know how can I delete a feature from a wms layer loaded
>     from a database postgres to geoserver and displayed using openlayer
>     , I don’t want to delete a feature from a vector layer but from a wms .
>     Thanks for ur help.
>     _______________________________________________
>     Users mailing list
>     Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
