[OpenLayers-Users] Does OpenLayers provide a way to check if a layer is available?
Phil Scadden p.scadden at gns.cri.nz
Tue Nov 27 12:59:58 PST 2012
is the 500 error persistent? (which would allow a change in your layer
list).
You can detect an issue with:
             layer.events.register("tileerror",layer,function(evt){
                  *your code*
but quite what you do in such a case is more interesting. Possibilities
- add both layers to map but make on invisible. On error, switch
visibility and return a transparent tile
               evt.tile.setImgSrc("images/empty.png");
               return false;
Good luck!
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
