[OpenLayers-Users] openlayers api changed?
Milo van der Linden milo at dogodigi.net
Wed Oct 3 12:02:42 PDT 2012
Hello Marc,
I made the following fixes to your source:
- In index.html added meta info about encoding
- set zoom to 5 (after discovering the objects where out of sight)
- Commented out the LayerTah. It doesn't seem to be available?
I had some issues converted your pasted textfile, I had to make sure all
spaces where correct and I found out that the 3th column containing
'21500Mhz' was not mapped resulting in OpenLayers unable to find the png's
Please find attached a working copy of your sample.
Kind regards,
Milo van der Linden
2012/10/3 Marc Coevoet <marcc at dommel.be>
> Hello,
> 3 years ago, I made a openlayers app with radio frequencies for FM and
> adjacent stations that could give noise.
> I see that suddenly the app no longer works.
> I will copy the code here:
> (images are on the right place ..)
> index.htm:
> <html xmlns="http://www.w3.org/1999/**xhtml <http://www.w3.org/1999/xhtml>
>   <head>
>     <style type="text/css">
> #map {
>         width: 100%;
>         height: 100%;
>         border: 0px;
>         padding: 0px;
>         position: absolute;
> body {
>         border: 0px;
>         margin: 0px;
>         padding: 0px;
>         height: 100%;
>     </style>
>     <script src="http://www.openlayers.**org/api/OpenLayers.js<http://www.openlayers.org/api/OpenLayers.js>
> "></**script>
>     <script src="http://www.openstreetmap.**org/openlayers/OpenStreetMap.*
> *js <http://www.openstreetmap.org/openlayers/OpenStreetMap.js>"></script>
>     <script type="text/javascript">
>         // complex map object
>         var map;
>         // Start position for the map (hardcoded here for simplicity,
>         // but maybe you want to get from URL params)
>         var lat = 50.89517;
>         var lon = 2.7206;
>         var zoom = 7;
>         function init(){
>             map = new OpenLayers.Map('map',
>                     { maxExtent: new OpenLayers.Bounds(-20037508.**
> 34,-20037508.34,20037508.34,**20037508.34),
>                       numZoomLevels: 19,
>                       maxResolution: 156543.0399,
>                       units: 'm',
>                       projection: new OpenLayers.Projection("EPSG:**
> 900913"),
>                       displayProjection: new OpenLayers.Projection("EPSG:*
> *4326")
>             var layerMapnik = new OpenLayers.Layer.OSM.Mapnik("**Mapnik");
>             var layerTah = new OpenLayers.Layer.OSM.**
> Osmarender("Tiles at Home");
>             map.addLayers([layerMapnik,**layerTah]);
>             var pois = new OpenLayers.Layer.Text( "My Points",
>                     { location:"./textfile.txt",
>                       projection: map.displayProjection
>             map.addLayer(pois);
>             map.addControl(new OpenLayers.Control.**LayerSwitcher());
>             var lonLat = new OpenLayers.LonLat(lon, lat).transform(map.**displayProjection,
>  map.projection);
>             if (!map.getCenter()) map.setCenter (lonLat, zoom);
>     </script>
>   </head>
>   <body onload="init()">
>     <div id="map"></div>
>   </body>
> </html>
> The textfile.txt starts like this :
> lat     lon     title   description     icon    iconSize        iconOffset
> 57.28528        10.10139        91.500MHz       Broenderslev
>     above sea 40m antenna height  40m erp h/v 22.0dBm/     dBm pol/dir /
> ../antenne.png      40,40   -20,-20
> 46.26750        10.11778        91.500MHz       Brusio
>     above sea 1097m antenna height  50m erp h/v 20.0dBm/     dBm pol/dir /
> 51.80139        10.61694        91.500MHz       Brocken
>      above sea 1140m antenna height  65m erp h/v 50.0dBm/     dBm pol/dir /
> 53.74444        10.70583        91.500MHz       Berkenthin
>     above sea 65m antenna height 147m erp h/v 30.0dBm/     dBm pol/dir /
> 48.90222        11.16306        91.500MHz       Eichstaett
>     above sea 470m antenna height  30m erp h/v 20.0dBm/     dBm pol/dir /
> 46.40083        11.28472        91.500MHz       Bolzano Montic
>     above sea 638m antenna height  97m erp h/v 30.0dBm/     dBm pol/dir /
> Where could te problem be?
> The fiels are uploaded to
> http://dxradio.woelmuis.nl/**research/fmmaps/<http://dxradio.woelmuis.nl/research/fmmaps/>
> (and the pub does'nt make a problem)
> Marc
> The "Penguin" has arrived - and he's not going away - ever.
> What's on Shortwave guide: choose an hour, go!
> http://shortwave dot tk
> 700+ Radio Stations on SW http://swstations dot tk
> 300+ languages on SW http://radiolanguages dot tk
> ______________________________**_________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121003/8faa3a12/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121003/8faa3a12/attachment.zip>
