[OpenLayers-Users] best way to show many static points
Toby Reinicke ramotswa at gmail.com
Tue Oct 9 13:18:25 PDT 2012
Well there we go then. As Phil also says, mapserver is good too, although I have no experience with it. Trouble with both is that you need to have some control over the data. (I.e load it into a db).
From what you have written it seems that this may be your stumbling block.
Toby
On 9 Oct 2012, at 21:12, Mike Ryan <m.ryan6000 at gmail.com> wrote:
> Hmmm... the plot thickens. Geoserver. Don't know a thing about it, yet.
> I'm not actually creating the tiles, someone else is, using TileMill and then, yes pulling in an XYZ Tile layer from MapBox.
> On 10/9/2012 4:07 PM, Toby Reinicke       wrote:
>> Ah ok. Some more information on your setup would be of interest. How do you build your mapbox tiles? Do you have a WMs server running? For my sins I haven't used mapbox much, and I presume you're pulling them in as a Tile layer? Passing in x,y,z params?
>> If I had these reqs I'd use geoserver in a heartbeat.
>> Toby
>> On 9 Oct 2012, at 20:55, Mike Ryan <m.ryan6000 at gmail.com> wrote:
>>> The problem with tiles in my situation -- and someone jump in here if this doesn't sound right -- is that they'd cover the entire state of New York from low to high zoom levels, like 10 to 17. We've done this just fine for a small part of NYC using MapBox, but it seems that to cover the entire state is cost prohibitive because we'd require such a huge amount of storage.
>>> Does that sound out of whack?
>>> The next strategy is to use tiles at low zoom levels and then switch over to loading points at the high levels.
>>> I'll mess around w/ the single tile idea you mention.
>>> Thanks
>>> On 10/9/2012 3:48 PM, Toby Reinicke wrote:
>>>> Hey,
>>>> So what's the problem with tiles? Server side stuff is your only choice really. Not going to load those points into a browser.
>>>> If its tiles you don't like you can always call the openlayers layer as a single tile? Slow down the rendering a bit but will just create the one image...
>>>> Toby
>>>> On 9 Oct 2012, at 20:35, m1k3ry4n <mr at mry4n.net> wrote:
>>>>> I have a situation where I'm going to have hundreds of thousands of points,
>>>>> and I'm wondering what the options are for displaying them other than using
>>>>> Tiles. These points are static, I do not need to interact with them, move
>>>>> them around, etc. Any thoughts?
>>>>> PS: On a separate note, I'm posting this from Nabble. I've been trying to
>>>>> send messages to the list for a month and the don't seem to be coming
>>>>> through. Maybe it's a subtle hint. In any case, if anyone has any ideas on
>>>>> what might be going on there, please let me know.
>>>>> Thanks!
>>>>> Mike
>>>>> View this message in context: http://osgeo-org.1560.n6.nabble.com/best-way-to-show-many-static-points-tp5007504.html
>>>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> Users mailing list
>>>>> Users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121009/48ee6d23/attachment-0001.html>
