[OpenLayers-Users] Highlighting Feature on KML Layer
Phil Scadden p.scadden at gns.cri.nz
Tue Oct 9 15:13:41 PDT 2012
> I am new to web mapping and to OpenLayers. I have created a basic map
> that has a base layer and a KML vector layer.  The features in the KML
> vector layer have several attributes.  When opening my map, is it
> possible to highlight and zoom to a specific feature in the KML vector
> layer based on one of the attributes?
You will note that google isnt good about providing that functionality
themselves in their products. KML is a very flexible format. You can
define attributes for a featureset in the set header and then provide
just the data for the feature ( as you would for a "normal" layer), but
you can also have attribute and data for each feature (ie each feature
could have different attributes). Furthermore the KML could just be a
network link.
In short, I dont think it is implemented in OL but maybe others would
prove me wrong. If you are stuck using KML vector files, then I think
you will need custom code to pick your way through a loaded KML layer
feature entries. If you have option of not using KML than I would
strongly consider it. If your data is in say geoserver then you can
create a WFS kml link to view in GE from your web application but using
KML directly is slow and limited.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121010/be10a2cd/attachment.html>
