[OpenLayers-Users] Rotate the line geometry with arrow - usingrotation style?
Arnd Wippermann arnd.wippermann at web.de
Fri Oct 19 09:17:25 PDT 2012
I'm pleased, that the example helped to solve your problem.
Instead of an MultiLineString you could also use a single LineString to draw
the arrow.
LINESTRING(0 0,0 8,-0.5 8,0 10,0.5 8,0 8)
updated example:
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/Direction_Vectors/rotation_
of_simple_direction_vectors.asp
BTW. You couldn't blame OpenLayers for not finding this example. I have just
created it as return to your post.
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von mikeluz
Gesendet: Freitag, 19. Oktober 2012 11:39
An: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] Rotate the line geometry with arrow -
Hi there
First of all thank you very much for the interest and for giving me some
idea how to do that. Maybe someone will have this same problem, so I will
write what I came up with. I think that there were 2 possible solutions for
this problem:
1. The one that was mentioned by *Jørgen S. Nicolaysen* Actually the style
definition was ok, and everything was ready to use. The only problem was
that during rotation the "angle" attribute was not changed.
I think it could be done with this code (not 100% working code, just an
idea):
/                var orginalFunction = myContorls.modify.dragControl.onDrag;
		myContorls.modify.dragControl.onComplete = function
(feature, pixel){
			orginalFunction.apply(this,arguments);
                        feature.attributes.angle = 180 // (feature is the
arrow!!!!)
                        feature.layer.drawFeature(features)
I really think that this should work. I have not tested it, I just had the
idea for it... For my problem I choose second approach
2. This was *Arnd Wippermann* idea. I have not seen this example before, and
I was really surprised how nice this idea was. Create line and polygon in
shape of an Arrowhead :) I mean how simple is that :)  I used it and it
works really great. Any code I guess is not needed. Everything is in that
example that Arnd shown me.
BTW. I find it really annoying that there was a solution online, but I was
not able to find it :( OL should put some links to their example page to
some other example that are available online. That would help a lot...
Thank you one more time!
Regards,
Pawel
View this message in context:
http://osgeo-org.1560.n6.nabble.com/Rotate-the-line-geometry-with-arrow-usin
g-rotation-style-tp5009318p5009833.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
