[OpenLayers-Users] Newbie: OpenLayers, Openstreetmap adding markers
Nicholas Efremov-Kendall n.e.kendall at gmail.com
Mon Oct 22 02:06:22 PDT 2012
Hi Robert,
You're question is a little too general to really be able to help you and
this list dedicated to the client side aspect of Open Layers.
Basically, you want an ajax call to your dbase to generate a vector layer
with markers writing the attributes you want to write to each locus. From
there, read the vector layer and popup examples. Finally, the zoom can be
solved a number of ways grabbing the bbox of the markers once they're
loaded.
hope that helps, I did something similar here www.sas.upenn.edu/jerba go to
the webgis section. If that's close to what you want to do, message me and
I can give you the php.
On Sun, Oct 21, 2012 at 7:03 AM, robertico <robert_rdk at hotmail.com> wrote:
> I'm currently running my own Openstreetmap server. I'd like to use
> OpenLayers and Openstreetmap to add markers on a map. I'd like to load the
> coordinates from a Ms-SQL database or text file and scale the map (correct
> zoom factor) to show all available markers. Also like to add extra
> information to a marker (visible after click) Who can provide me a sample?
> Regards, Robert
> View this message in context: Newbie: OpenLayers, Openstreetmap adding
> markers<http://osgeo-org.1560.n6.nabble.com/Newbie-OpenLayers-Openstreetmap-adding-markers-tp5010128.html>
> Sent from the OpenLayers Users mailing list archive<http://osgeo-org.1560.n6.nabble.com/OpenLayers-Users-f3910695.html>at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121021/c93a167b/attachment.html>
