[OpenLayers-Users] How to remove vector layer properly or just peieces of a vector layer?
miguel juanabreu at hotmail.com
Wed Oct 31 04:19:18 PDT 2012
Hi guys I've been racking my head on how to remove just the vector layer
from my map. Below is my code I  have a function call killLayer(), but it
does not work at all I have try different variations. So I just need to
understand if I add a layer in my init function, how can I get a reference
to that layer to remove later on from another function. In this case my
vector layer. I would like to remove it and just keep the base layer. Any
help would be immensely appreciated.
Miguel
My Code:
                   var map;
                   var lineLayer = new OpenLayers.Layer.Vector("LineLayer");
                   var mapBounds = new OpenLayers.Bounds( 0.0, -906.0,
800.0, 0.0);
                    var mapMinZoom = 0;
                    var mapMaxZoom = 7;
                   // avoid pink tiles
                   OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
                   OpenLayers.Util.onImageLoadErrorColor = "transparent";
                   function init(){
                       var navigation_control = new
OpenLayers.Control.Navigation({});
                       var controls_array = [
                                    navigation_control,
                                    new OpenLayers.Control.PanZoomBar({}),
                                    new
OpenLayers.Control.LayerSwitcher({}),
                                    new OpenLayers.Control.Permalink(),
                                    new OpenLayers.Control.MousePosition({})
                var options = {
                     controls: [],
                       maxExtent: new OpenLayers.Bounds(  0.0, -906.0,
800.0, 0.0 ),
                       maxResolution: 4.000000,
                       numZoomLevels: 8
    //{controls: controls_array}
                   map = new OpenLayers.Map('map', options ); ;
                //tile map service TMS stands for tile map service.
                   var layer = new OpenLayers.Layer.TMS( "TMS Layer","",
                       {  url: '', serviceVersion: '.', layername: '.',
alpha: true,
                           type: 'png', getURL: overlay_getTileURL
                   map.addLayer(layer);
                     map.zoomToExtent( mapBounds );
                     //create the new layer vector layer which includes all
the drawings.
                     /*here im addding to lines separate line segments.*/
                     map.addLayer(lineLayer);
                     var points = new Array(
                     new OpenLayers.Geometry.Point(56.0000, -244) ,  //x and
y cordinate of first point
                     new OpenLayers.Geometry.Point(368,-248)       //x and y
cordinate of the second point
                     var second_segment = new Array(
                     new OpenLayers.Geometry.Point(480,-230),  //x and y
                     new OpenLayers.Geometry.Point(668,-250)  //x and y
                     var line  = new OpenLayers.Geometry.LineString(points);
                     var line2  = new
OpenLayers.Geometry.LineString(second_segment);
                     var style={
                     strokeColor: '#0000ff',
                      strokeOpacity: 0.5,
                      strokeWidth: 6};
                     var lineFeature = new OpenLayers.Feature.Vector(line,
null, style);
                     var lineFeatureN = new OpenLayers.Feature.Vector(line2,
null, style);
                     lineLayer.addFeatures([lineFeature]);
                     lineLayer.addFeatures([lineFeatureN]);
                 map.addControl(new OpenLayers.Control.PanZoomBar());
                 map.addControl(new OpenLayers.Control.MousePosition());
                 map.addControl(new OpenLayers.Control.MouseDefaults());
                 map.addControl(new OpenLayers.Control.KeyboardDefaults());
             function killLayer() {
                 //map.removeLayer("LineLayer");
                 //lineLayer.destroy();
                //map.destroy("LineLayer");
                lineLayer.removeFeatures(lineFeature);
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20121031/6f032572/attachment-0001.html>
