[OpenLayers-Users] registering a click event on a map
Puneet Kishor punk.kish at gmail.com
Tue Sep 11 17:20:11 PDT 2012
On Sep 10, 2012, at 7:16 PM, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> On Mon, Sep 10, 2012 at 1:38 PM, Puneet Kishor <punk.kish at gmail.com> wrote:
>> In OL 2.11 I used to do the following successfully
>>    map.events.register(
>>        "click",
>>        map,
>>        function(e) {
>>            fancyFunction({evt: e, other_params: "foo"});
>> The above has stopped working in Firefox (currently using FF v. 15.0.1) without any errors. It does work in Safari 6, but gives the following warning in the console.log
>>> event.layerX and event.layerY are broken and deprecated in WebKit. They will be removed from the engine in the near future.
>> Suggestions to fix both problems would be welcomed with thanks.
> I believe the correct way to register a click handler is something like:
> var click = new OpenLayers.Control.Click( {
>  trigger: function(e) {
>    /* do stuff */
> map.addControl(click);
> click.activate();
Perhaps. But, when I use the above code, I get the following error
	TypeError: OpenLayers.Control.Click is not a constructor
I don't get any error when I use the following code (snitched from the example online), but the trigger function doesn't fire. Nothing happens.
    OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, {
        defaultHandlerOptions: {
            'single': true,
            'double': false,
            'pixelTolerance': 0,
            'stopSingle': false,
            'stopDouble': false
        initialize: function(options) {
            this.handlerOptions = OpenLayers.Util.extend(
                {}, this.defaultHandlerOptions
            OpenLayers.Control.prototype.initialize.apply(
                this, arguments
            this.handler = new OpenLayers.Handler.Click(
                this, {
                    'click': this.trigger
                }, this.handlerOptions
            fancyFunction(e);
    var click = new OpenLayers.Control.Click();
    map.addControl( click );
    click.activate();
Finally, note that my way listed above in my OP actually works in webkit (Safari and Chrome) but not in Firefox. So, what is going on?
Puneet Kishor
