[OpenLayers-Users] Modify feature Before insert from DrawFeature Control
Mark Paxton
mark at innaxys.com
Wed Sep 19 05:51:48 PDT 2012
Hi, thanks for getting back to me so quickly!
On 19/09/2012 13:40, Bart van den Eijnden wrote:
> How about using the beforefeatureadded event of OpenLayers.Layer.Vector?
The problem is this is fired when I load data from my HTTP protocol as
well as through DrawFeature. My workaround-in-progress is to check if
the desired properties are already set or not, but there should be a
nicer way I'm sure!
Mark
> Best regards,
> Bart
> OpenGeo - http://opengeo.org <http://opengeo.org/>
> Expert service straight from the developers.
> On Sep 19, 2012, at 2:37 PM, Mark Paxton <mark at innaxys.com
> <mailto:mark at innaxys.com>> wrote:
>> Hello,
>> Please may I ask some advice on the following:
>> I would like to set properties on a feature when inserted from a
>> DrawFeature control. At the moment I use the 'featureAdded' event on
>> Control.DrawFeature, however the 'beforeFeatureAdded' event should be
>> what I need as I am setting properties for the style, etc. How can I
>> achieve this without havingt o create a new layer?
>> Thanks
>> Mark
>> Users mailing list
>> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120919/1e32da9d/attachment.html>
