[OpenLayers-Users] Unable to project WFS properly
Phil Scadden p.scadden at gns.cri.nz
Thu Sep 20 14:17:38 PDT 2012
Unless you use OpenLayers.Protocol.WFS.v1_1_0 and specify the SRS of
your map in the protocol constructor, then you will be fetching data in
the native SRS which might not match the map. Does your server support
WFS 1.1.0? If not then you will have to make sure you have proj4 def
available on the client and project on the client.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
