[OpenLayers-Users] Access to KML attributes
cbaldinu
cbaldinu at gmail.com
Tue Sep 25 05:48:30 PDT 2012
Ok, i understood.
I post my code so, i hope, you can give me help just to put all together
Here is my js code:
var sundials = new OpenLayers.Layer.Vector("KML", {
projection: map.displayProjection,
strategies: [new OpenLayers.Strategy.Fixed()],
protocol: new OpenLayers.Protocol.HTTP({
url: "custom_kml.kml",
format: new OpenLayers.Format.KML({
extractStyles: true,
extractAttributes: true
controls = {
drag: new OpenLayers.Control.DragFeature(sundials,
onComplete : getLatLon
for(var key in controls) {
map.addControl(controls[key]);
function getLatLon(event){
var coord = this.feature.geometry.transform(
new OpenLayers.Projection("EPSG:900913"),
new OpenLayers.Projection("EPSG:4326")
alert('you clicked on '+coord.x+' N and '+coord.y+' E');
What i want to do, after i drag a point, is, instead of printing an alert (
in the code is alert('you clicked on '+coord.x+' N and '+coord.y+' E');), i
would like to print my id, just to use it with $.post() function on jquery
and make an update script on my DB.
In addition, how could i add a custom id on the kml so i can call that on a
jquery call?
Thanks,
Cristian Baldinu
View this message in context: http://osgeo-org.1560.n6.nabble.com/Access-to-KML-attributes-tp5004222p5004257.html
