[OpenLayers-Users] HOWTO: GWC, layer MaxExtent - setting it up correctly to avoid misaligned tiles
Phil Scadden p.scadden at gns.cri.nz
Thu Sep 27 17:01:50 PDT 2012
Having battled with this on and off for quite a while, I think I finally
have a solution.
If you are using WMS with a caching system, (eg GeoWebCache), and put a
restriction on a layer extent, then you can end up with mess.
Symptoms, - misalignment of layers with basemap, repetition of parts of
a layer on a map.
The cause is Openlayers issuing BBOX requests that dont align with GWC
tiles.
The fix. If you are going to specify a maxExtent on a layer, you MUST
also supply a tileOrigin
eg code.
layer = new OpenLayers.Layer.WMS(name, serverUrl, { layers: layerName,
tiled:true, transparent: true },
  { tileOrigin: new
OpenLayers.LonLat(map.maxExtent.left,map.maxExtent.bottom),
maxExtent:myMaxExtent, });
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
