[OpenLayers-Users] Rotation based on database field
ramaralo mail.roliveira at gmail.com
Tue Apr 2 07:54:42 PDT 2013
I'm trying to create an OpenLayers.Rule like this:
var rule = new OpenLayers.Rule({
				filter: andFilter,
				symbolizer: {
					"Point": {
						rotation: model.pointAttributes.rotation
this works fine if /model.pointAttributes.rotation/ is a Number and later
this rule will be converted to this SLD
<sld:Rotation>20</sld:Rotation>
when calling OpenLayers.Format.SLD().write where I pass an OpenLayers.Style
object wich contains the above OpenLayers.Rule.
*My problem is* I want to support String in /model.pointAttributes.rotation/
as well as Number. And if a String is provided the generated SLD should be
(imagine the value is "azimuth"):
<sld:Rotation><ogc:PropertyName>azimuth</ogc:PropertyName></sld:Rotation>
The point here is to make rotation, dependent on the azimuth database field.
This SLD works if built on Geoserver, but I want to create it dynamically on
the client side so I can append it to the sld_body parameter request.
I've looked into the openLayers api documentation, and can't seem to find a
way to create a PorpertyName SLD object or any other way to achieve the same
result.
Any ideas on how to solve this?
Thanks in advance.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Rotation-based-on-database-field-tp5044094.html
