[OpenLayers-Users] Is point visible
Christer Nordbø christer at gdm.no
Fri Apr 5 00:44:53 PDT 2013
Others, who have done something similar ( i guess ) have marked the area, either with an invisible polygon, and then check if its visible. Or you can find out at which bounds the city is visible in and use the map.getExtent to get the BBOX and check if the city bounds are within the viewport BBOX (Bounding Box).
http://dev.openlayers.org/apidocs/files/OpenLayers/BaseTypes/Bounds-js.html#OpenLayers.Bounds
Med vennlig hilsen / Kind regards,
Christer Nordbø
From: "Macbeth, Andrew (US SSA)" <andrew.macbeth at baesystems.com<mailto:andrew.macbeth at baesystems.com>>
Date: Thu, 4 Apr 2013 19:18:00 +0000
To: "openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>" <openlayers-users at lists.osgeo.org<mailto:openlayers-users at lists.osgeo.org>>
Subject: [OpenLayers-Users] Is point visible
I’ve poked around and around and don’t a means to determine whether a given point is visible to the user. For example, if the user has scrolled the map away from Boston such that it can not be seen, how can I determine that?
_______________________________________________ Users mailing list Users at lists.osgeo.org<mailto:Users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130405/d334d346/attachment.html>
