[OpenLayers-Users] Setting layer maxResolution and numZoomLevels
rickm81 rickm81 at yahoo.com
Fri Apr 5 08:54:34 PDT 2013
I'm new to OpenLayers and experiencing some trouble with setting
maxResolution and numZoomLevels on a layer. I would like the max value to be
lesser (more zoomed in) than the default value.
The code below is a simple map init function. I have tried setting the
maxResolution, maxScale, and numZoomLevel properties in both the map and
layer constructors with no luck. The line that is commented out was a
suggestion on another forum that seemed to work, but I was not able to
change these values to something that would work for me.
            var EPSG4326 = new OpenLayers.Projection("EPSG:4326");
            var EPSG900913 = new OpenLayers.Projection("EPSG:900913");
            var newbounds = new OpenLayers.Bounds(-20037508.3427892,
-20037508.3427892, 20037508.3427892, 20037508.3427892);
            var lat = 42.68;
            var lon = -71.409;
            var zoom = "10";
            var centre = new OpenLayers.LonLat(lon, lat).transform(EPSG4326,
EPSG900913)
            var extent = newbounds.transform(EPSG4326, EPSG900913);
            var map;
            function init() {
                map = new OpenLayers.Map("map", {
                    controls: [
                        new OpenLayers.Control.MouseDefaults(),
                        new OpenLayers.Control.Permalink(),
                        new OpenLayers.Control.PanZoomBar()],
                    displayProjection: new
OpenLayers.Projection("EPSG:4326"),
                //var OSMLayer = new OpenLayers.Layer.OSM(("OSM"),"",{
isBaseLayer: true, zoomOffset: 11, resolutions: [76.4370282714844,
38.2185141357422, 19.1092570678711, 9.55462853393555, 4.77731426696777,
2.38865713348389, 1.19432856674194] });
                var OSMLayer = new OpenLayers.Layer.OSM("OSM");
                map.addLayer(OSMLayer);
                map.addControl(new OpenLayers.Control.Attribution());
                map.addControl(new OpenLayers.Control.KeyboardDefaults());
                map.setOptions({ restrictedExtent: extent })
                if (!map.getCenter()) { map.setCenter(new
OpenLayers.LonLat(lon, lat).transform(EPSG4326, EPSG900913), zoom); }
I am working in .NET MVC 4. Are there any known issues in Open Layers with
this framework or with OSM? It seems easy enough to define these properties,
but I am having all kinds of problems. Any help would be much appreciated.
Thanks!
Rick
View this message in context: http://osgeo-org.1560.n6.nabble.com/Setting-layer-maxResolution-and-numZoomLevels-tp5044883.html
