[OpenLayers-Users] How to add multiple symbols for all points from a vector layer?
Christer Nordbø
christer at gdm.no
Tue Apr 9 00:33:11 PDT 2013
You could go trough every point, and create a new vector for each of the
point. Or gather a bunch of markers in 1 vector. You could use a image if
the symbols does not change to a random structure. And add it on the the
map as a Marker vector.
http://www.openlayers.org/dev/examples/markers.html
Med vennlig hilsen / Kind regards,
Christer Nordbø
System developer
Global Digital Media
Gamle Forusvei 8, 4033 Stavanger, Norway
On 09.04.13 03:48, "Phil Scadden" <p.scadden at gns.cri.nz> wrote:
>Well its trivial to do with an SLD on a WMS layer but I dont know a lot
>about styles for vector layer. You could construct an SLD and then read
>it with OpenLayers.Format.SLD() and see if it works (eg
>http://www.openlayers.org/dev/examples/sld.js)
>However, if the styles object doesnt support layering, you can always
>make the point in an external graphic file and use that.
>Notice: This email and any attachments are confidential.
>If received in error please destroy and immediately notify us.
>Do not copy or disclose the contents.
>_______________________________________________
>Users mailing list
>Users at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/openlayers-users
