[OpenLayers-Users] Problem by update ol212 - tiles not show andlost by move
Arnd Wippermann
arnd.wippermann at web.de
Mon Apr 15 09:10:53 PDT 2013
Hi Jan,
most likely you have to set in the tileOptions the key crossOriginKeyword to
null
/** APIProperty: tileOptions
* {Object} optional configuration options for <OpenLayers.Tile>
instances
* created by this Layer. Default is
* (code)
* {crossOriginKeyword: 'anonymous'}
* (end)
* When using OSM tilesets other than the default ones, it may be
* necessary to set this to
* (code)
* {crossOriginKeyword: null}
* (end)
* if the server does not send Access-Control-Allow-Origin headers.
tileOptions: null,
https://github.com/openlayers/openlayers/blob/master/notes/2.12.md#osm-and-b
ing-layers
Arnd
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Jan
Tappenbeck
Gesendet: Montag, 15. April 2013 14:36
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] Problem by update ol212 - tiles not show andlost
by move
Hallo !
i try to update a website from ol210->ol211 for using table-devices.
i should have make all request mimigration-edits but i have a little
problem:
* the tiles of map will come by the wikipedia.tile-server - will not show,
but no error-message in the firebug. when i copy the url to the wik-tiles a
image will show !
did i have forget something in the function
OpenLayers.Layer.OSM.Toolserver =
OpenLayers.Class(OpenLayers.Layer.OSM, {
initialize: function(name, options) {
var url = [
"http://a.www.toolserver.org/tiles/" + name +
"/${z}/${x}/${y}.png",
"http://b.www.toolserver.org/tiles/" + name +
"http://c.www.toolserver.org/tiles/" + name +
options = OpenLayers.Util.extend({numZoomLevels: 19}, options);
OpenLayers.Layer.OSM.prototype.initialize.apply(this, [name, url,
options]);
CLASS_NAME: "OpenLayers.Layer.OSM.Toolserver"
at the mimigration to ol212 ??
* the tiles of myself (port-names on the layer "label_en") will lost, when
move the map by middle-mouse-button. when i zoom in/out buy button is ok !
the side is: http://osm.tappenbeck.net/ferry2013/deu/ferry_iframe.php
(there commes a error-message window.parent.set_active_port is not a
function - when click to a red-marker -> ignore it!!
secound-questions: when a png-file is missing there comes a message too
- but in the screen.css-file i added:
.olImageLoadError {
display: none;
did anyone could help me ?
regards Jan :-)
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
