[OpenLayers-Users] XYZ Layer with zoom and extent restrictions
semiaddict news at semiaddict.com
Mon Apr 29 08:13:16 PDT 2013
Thank you David.
I had stumbled upon a similar answer and tried that solution, but it did not
work in my case.
Would you mind posting an example with your solution ?
Note: you should not need to patch OpenLayers.Layers.XYZ as I believe you
can override a method by adding it as an option to the layer
View this message in context: http://osgeo-org.1560.x6.nabble.com/XYZ-Layer-with-zoom-and-extent-restrictions-tp5050252p5050270.html
