[OpenLayers-Users] Mapfish and GeoExt PrintProvider issue
Brad Bordine
b.bordine at decapower.org
Mon Dec 16 19:47:30 PST 2013
I am trying to make a Ext grid object print out via mapfish print and am
unclear how to send the "grids" parameter through the spec. There is an
example of a user sending the grids parameter to the Mapfish "print
widget (http://web.archiveorange.com/archive/v/0qLmXVvRWkxmMKrmM5kL)
however no one mentions how to do that using the print.provider GeoExt
widget, which seems to be the object communicating with the server
Mapfish widget. We are aware of the need for configuring the YAML but at
the moment are trying to figure out how to get the right spec. Relevant
snippets are below
avoidedgrid = new Ext.grid.GridPanel({
title: "Total Avoided Costs for 1MW at Specified Location",
renderTo: "gridoutput",
height:75,
width:365,
collapsible: true,
iconCls: 'icon-grid',
ds: ds,
cm: colModel
var printProvider = new GeoExt.data.PrintProvider({
method: "POST", // "POST" recommended for production use
layout: ('Letter'),
capabilities: printCapabilities, // from the info.json script
in the html
customParams: {
mapTitle: "DECA Map",
dpi: 300,
grids: [avoidedgrid]
