[OpenLayers-Users] popup outside map boundaries
Gery . gamejihou at hotmail.com
Tue Feb 19 06:11:10 PST 2013
Hola Jorge,
Do you have an example? some code about your problem? o a lo mejor explicar el problema en español si lo hablas?
Sent from my iBath
On Feb 19, 2013, at 15:02, "jvonrudno" <jvonrudno at hotmail.com> wrote:
Hi everybody,
I have a marker that show a popup when the mouse is over the marker. This
popup some times show information that is  outside of the boundaries of the
map. I need to show the complete info that brings the pop up with out using
the scroll bar. So  my question is how can I show the popup that superimpose
the div of the map.
In advance thousands thanks.
Regards
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/popup-outside-map-boundaries-tp5035197.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
