[OpenLayers-Users] Two displayProjections on a map
Jan Hartmann j.l.h.hartmann at uva.nl
Thu Jan 10 05:02:54 PST 2013
Hi Rich, how did you get the lon-lat values on your map formattted as
degrees/minutes/seconds (next to the default decimal degrees?)
Jan
On 1/9/2013 3:54 PM, Richard Greenwood wrote:
> On Wed, Jan 9, 2013 at 5:40 AM, Jan Hartmann <j.l.h.hartmann at uva.nl
> <mailto:j.l.h.hartmann at uva.nl>> wrote:
>     Is it possible to have tow displayprojections on a map? I would
>     like to show the actual mouse position both in WGS84 latlon
>     (epsg:4326) and in the projection of the map I am working on.
>     Changing the projection in the Javascript file and starting the
>     application anew does the trick, but I would like to see both
>     coordinate pairs at the same time. Is there a trick to do this?
>     Jan
> Sure! Here's an example:
> http://maps.greenwoodmap.com/tetonwy/mapserver/map
> <http://maps.greenwoodmap.com/tetonwy/mapserver/map>
> Richard Greenwood
> richard.greenwood at gmail.com <mailto:richard.greenwood at gmail.com>
> www.greenwoodmap.com <http://www.greenwoodmap.com>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130110/66ad986f/attachment.html>
