[OpenLayers-Users] How to draw a arrow with openlayer?
杨华杰 yhjhoo at gmail.com
Thu Jan 24 20:06:24 PST 2013
Hi Guys
I got some process.
But I have a problem to draw with the mouse, during the drawing, I can see
the angle. But when I double click, the angle gone. Any tips will help.
Regards,
Hua Jie
On Thu, Jan 24, 2013 at 10:01 AM, 杨华杰 <yhjhoo at gmail.com> wrote:
> Hi Imran
> Thanks for your reply. I believe a lot people have the same questions. Why
> this feature is not released.
> Regards,
> Hua Jie
> On Wed, Jan 23, 2013 at 10:28 PM, Imran Rajjad <rajjad at gmail.com> wrote:
>> Hi,
>> you can make a feature whose geometry is a GeometryCollection, this
>> collection can contain a line and a point grouped into one geometry then
>> you can use the below mentioned style to draw an arrow with your line
>> strokeColor: "#00688B",
>>     fillColor: "#00688B",
>>     fillOpacity : 1.0,
>>     strokeWidth: 2,
>>     strokeOpacity : 0.9,
>>     pointRadius: 6,
>>     graphicName :"triangle",
>>     rotation :angle
>> remember to compute the angle before setting this .. you should be able
>> to calculate angle between start and end point of your line segment.. and
>> also the position of point geometry which will be drawn as triage with
>> given rotation angle..
>> Hope I got my point through..
>> regards,
>> Imran
>> On Wed, Jan 23, 2013 at 7:11 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
>>> Hi Alexandre
>>> Thank you, I will try this.
>>> Regards,
>>> Hua Jie
>>> On Wed, Jan 23, 2013 at 10:01 PM, Alexandre Dubé <adube at mapgears.com>wrote:
>>>>  Hi Hua Jie,
>>>> You could try to define your own arrow symbol.  There's one defined
>>>> [here], see line 1 :
>>>>   OpenLayers.Renderer.symbol.arrow = [0,2, 1,0, 2,2, 1,0, 0,2]
>>>>    I haven't tried it, but it could do the trick.
>>>> HTH,
>>>> Alexandre
>>>> [here]
>>>> http://code.google.com/p/rep-olnet/source/browse/trunk/Direction.js?r=61
>>>> On 13-01-23 07:09 AM, 杨华杰 wrote:
>>>> Hi
>>>>  As the title
>>>>  I know how to draw a line, dot, polygon. But my customer need some
>>>> directions on the map
>>>>  Regards,
>>>> Hua Jie
>>>> _______________________________________________
>>>> Users mailing listUsers at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-users
>>>> Alexandre Dubé
>>>> Mapgearswww.mapgears.com
>>>> Users mailing list
>>> Users mailing list
>> I.R
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130125/5cc65125/attachment.html>
