[OpenLayers-Users] How to draw a arrow with openlayer?
Arnd Wippermann arnd.wippermann at web.de
Fri Jan 25 02:25:27 PST 2013
may be this examples can help:
approach like Imran described
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL210/Line_Direction/direction_ar
row.asp
http://gis.ibbeck.de/ginfo/apps/OLExamples/OL212/Direction_Vectors/rotation_
of_simple_direction_vectors.asp
Arnd
  _____
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von ???
Gesendet: Freitag, 25. Januar 2013 05:06
An: Imran Rajjad
Cc: openlayers-users at lists.osgeo.org
Betreff: Re: [OpenLayers-Users] How to draw a arrow with openlayer?
Hi Guys
I got some process.
But I have a problem to draw with the mouse, during the drawing, I can see
the angle. But when I double click, the angle gone. Any tips will help.
Regards,
Hua Jie
On Thu, Jan 24, 2013 at 10:01 AM, 杨华杰 <yhjhoo at gmail.com> wrote:
Hi Imran
Thanks for your reply. I believe a lot people have the same questions. Why
this feature is not released.
Regards,
Hua Jie
On Wed, Jan 23, 2013 at 10:28 PM, Imran Rajjad <rajjad at gmail.com> wrote:
you can make a feature whose geometry is a GeometryCollection, this
collection can contain a line and a point grouped into one geometry then you
can use the below mentioned style to draw an arrow with your line
strokeColor: "#00688B",
    fillColor: "#00688B",
    fillOpacity : 1.0,
    strokeWidth: 2,
    strokeOpacity : 0.9,
    pointRadius: 6,
    graphicName :"triangle",
    rotation :angle
remember to compute the angle before setting this .. you should be able to
calculate angle between start and end point of your line segment.. and also
the position of point geometry which will be drawn as triage with given
rotation angle..
Hope I got my point through..
regards,
Imran
On Wed, Jan 23, 2013 at 7:11 PM, 杨华杰 <yhjhoo at gmail.com> wrote:
Hi Alexandre
Thank you, I will try this.
Regards,
Hua Jie
On Wed, Jan 23, 2013 at 10:01 PM, Alexandre Dubé <adube at mapgears.com>
wrote:
Hi Hua Jie,
You could try to define your own arrow symbol.  There's one defined  [here],
see line 1 :
  OpenLayers.Renderer.symbol.arrow = [0,2, 1,0, 2,2, 1,0, 0,2]
   I haven't tried it, but it could do the trick.
HTH,
Alexandre
[here]
http://code.google.com/p/rep-olnet/source/browse/trunk/Direction.js?r=61
On 13-01-23 07:09 AM, 杨华杰 wrote:
Hi
As the title
I know how to draw a line, dot, polygon. But my customer need some
directions on the map
Regards,
Hua Jie
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
Users mailing list
Users mailing list
I.R
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130125/df87a082/attachment.html>
