[OpenLayers-Users] OpenLayers.Class withOpenLayers.Control.GetFeature
Gery . gamejihou at hotmail.com
Wed Jan 30 15:01:17 PST 2013
thanks Arnd, I added your suggestion and it still complains about the same but after some a couple of clicks or boxes it sends the request, however the sent bbox is still in UTM, where could the problem be? here you can take a look at the code:
var mycontrol = function(){
            var protocol = new OpenLayers.Protocol.HTTP({
                url: 'http://www.r2d2.starwars/',
                format: new OpenLayers.Format.GeoJSON({
                    ignoreExtraDims: true,
                    'internalProjection': new OpenLayers.Projection('EPSG:900913'),
                    'externalProjection': new OpenLayers.Projection('EPSG:4326')
            OpenLayers.Control.myGetFeature = OpenLayers.Class(OpenLayers.Control.GetFeature,{
                selectBox: function(position){
                    var opts = OpenLayers.Control.GetFeature(position);
                    var baseSRSutm = this.map.getprojectionObject();
                    console.log('this is the baseSRSutm' + baseSRSutm);                     <--- this console.log doesnt appear in firebug
                    var layerSRSdd = new OpenLayers.Projection('EPSG:4326');
                    opts.params.bbox = this.map.getExtent().transform(baseSRSutm,layerSRSdd).toBBOX(null,firstLayer.reverseAxisOrder());
                    console.log('this is the opts.params.bbox' + opts.params.bbox);      <--- this console.log doesnt appear in firebug
                    return opts;
                CLASS_NAME: "OpenLayers.Control.myGetFeature"
          return new OpenLayers.Control.myGetFeature({
                protocol: protocol,
                box: true,
                click: true,
                single: false,
                clickTolerance: 10,
                eventListeners:{
                    // May the Force be with you
because the console.log doesnt appear in firebug, I think the problem is in the OpenLayers.Control.myGetFeature and OpenLayers.Class. It seems to me that the "selectBox" function is the one I need, but the subclass itself is not read by the return.
Gery
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
To: gamejihou at hotmail.com
CC: openlayers-users at lists.osgeo.org
Subject: AW: [OpenLayers-Users] OpenLayers.Class withOpenLayers.Control.GetFeature
Date: Wed, 30 Jan 2013 23:34:13 +0100
try
this:
opts.params.bbox =
return opts;
CLASS_NAME:
"OpenLayers.myGetFeature"
It seems, that a class needs a CLASS_NAME.
Arnd
Von: Gery . [mailto:gamejihou at hotmail.com]
Gesendet: Mittwoch, 30. Januar 2013 18:53
An:
arnd.wippermann at web.de
Cc:
Betreff: RE: AW: [OpenLayers-Users]
Thanks for that Arnd, now it
stops complaining about the missing "}", but now it appears
"TypeError:
this.CLASS_NAME is undefined", what and where should I put
there?
Piensa
si NO es necesario.
necessary.
Denken Sie an die
ist.
CC:
18:13:50 +0100
move 'return opts;' into the function
body:
opts.params.bbox = ...
return opts;
to get rid of
the error.
Arnd
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Gery
Gesendet: Mittwoch, 30. Januar 2013 16:52
An:
Betreff: [OpenLayers-Users]
Hi
all,
I'm wondering if someone could point me in the right
direction to force the BBOX
of OpenLayers.Control.GetFeature to be always in long/lat coordinates. I'm trying
to get this with OpenLayers.Class, so
the new control will inherit
OpenLayers.Control.GetFeature with just the small modification in BBOX. This is what I've
done:
                var baseSRSutm =
                opts.params.bbox =
    return opts;
but I'm getting that some "}" are missing. Is this the right way to use OpenLayers.Class to do what I want?
Any help is much appreciated.
Gery
Piensa
si NO es necesario.
necessary.
Denken Sie an die
ist.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130130/bc1f3ac8/attachment-0001.html>
