[OpenLayers-Users] Label Middle of Line
Jürgen Dankoweit
Juergen.Dankoweit at T-Online.de
Fri Jul 19 20:32:20 PDT 2013
Hello,
Am 19.07.2013 19:19, schrieb boesiii:
> I am trying to add a label for a line and would like the label to display at
> the midpoint. It looks like this isn't available OOTB. Does anyone have
> some code samples they wold like to share?
A possible solution is the following:
First set the attribute of the style/styleMap "labelAlign" to the value "cm"
Then use the function "getCentroid" from the geometry object to
calculate the center point of the line.
I hope this helps you.
Best regards
Juergen
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Meine stets unfertige Homepage: www.dankoweit.de
